Question about Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
I am having a problem figuring out how to remove the timer knob on an MDE7400AYW dryer. Can you help
  • bbappliance Apr 25, 2009
    IM STUCK TRYING TO GET THE KNOB ON MY ATLANTIS TO STAY ON WHAT DO I DO
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Posted on Jul 21, 2008
  • Rick Thomas
    Rick Thomas Jun 09, 2018
    There should be a part number on the timer itself.
  • Jeff Sluss
    Jeff Sluss Jun 10, 2018
    The only difference is the color. W is white q is bisque. They will use the same timer.
I was having the same problem until I figured out that you can remove the front part of the knob by gently prying the silver/gray cover away from the rubber ring part of the knob. Once you remove the front part the rest of the knob can be removed.
Posted on Jun 03, 2008
  • Connie Kasper
    Connie Kasper Jan 29, 2015
    Diagnosing was not a problem for me, but I could not find instruction to remove the knob on my Maytag Model LAT8106aae. Most instructions are from behind the contro panel. I was looking in the wrong place! Once I reoved the gray rubber ring, everything else was easy. Thanks for the solution.
    President:
  • Maytag Master
  • 2,651 Answers
After you gain acess inside the control panel, youll see the back of timer( there should be a small black shaft in the middle), with a small screw driver you can hold the very bottom of the shaft and pull it down(it pushes a small lock up the shaft and locks the knob in place) a little tinkering will get itafter the shaft is unlocked knob can be removed after replacing remomber to push "locktab" back or knob will fall right off
Posted on Mar 04, 2008
Solution #2 worked great for my Maytag Atlantis dryer Model MDE6400AYW
Posted on Jun 13, 2008
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
The Timer Knob on my Maytag Dryer does not move. The drying just goes on and on unless I notice and stop the dryer.
While the dryer is turning slowly advance the timer knob to the end of the cycle. The dryer should stop. It sounds as if the timer motor has died or is not being powered for some reason and is not advancing the timer.
Nov 12, 2009 | Maytag Clothes Dryer Almond Timer Knob...
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Feb 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How to remove control knob on maytag mde8400ayw timer
youll need to "pop" the center of the dryer knob off, the outer mos part of the knobin which oyou turn is a false front, that actually locks the knob onto the timer shaft, use a small screw driver to pry it off
Jan 25, 2009 | Maytag Atlantis MDE8400AY Electric...
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing timer switch
If you are replacing the timer, after you unplug it, first pop the plastic cap off the knob of the timer. Underneath you will find a small clip on the timer shaft that holds the knob on and makes it imposible to get the timer out without daming the know. Use a small flat head screwdriver to slide the clip to the side. Now you can remove the rest of the knob and the screws holding the timer in place. Next remove the screws along the top of the console. Push forward on the bottom of the console while gently pulling the top towards you. You will now see your timer laying there. Release the catch on the connector that holds all of the wirse to the timer. Reverse the process for instalation.
Jul 16, 2008 | Maytag MDE2600 Electric Dryer
Removing Timer knob on Kenmore Electric dryer
Normally, to remove the timer knob, simply push in on the timer knob and turn the knob counter clockwise. it should unscrew itself. If it does not, the shaft inside the timer has broken and the shaft simply free wheels so then you need to take a needle nose pliers to hold the shaft and then you can turn the knob or pull it off
Let me know if you have any further questions
Jun 04, 2008 | Dryers
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Maytag Atlantis MDE7400AY Electric Dryer Logo
3,343 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
