My computer is displaying a message about the recovery disk is running out of space, I have cleaned it and it is still displaying this message, what shall I do?
  • 40 Answers
Sometimes manufactures make the recovery partition so small that windows sees it as low space hard drive, it is annoying, as you arn't even supposed to save data to it anyway (it is reserved for emergency recovery) your best bet is to turn off windows disk monitoring, the only trade off is that if you C: drive gets full, windows won't warn you (but you should be able to monitor it on your own anyway.
goto START then RUN and type REGEDIT.EXE and push enter
Navigate to
HKEY_CURRENT_USER\ Software\ Microsoft\ Windows\ CurrentVersion\ Policies\ Explorer
If it's not there, create a DWORD value and call it NoLowDiskSpaceChecks.
Double-click on NoLowDiskSpaceChecks, and enter the value 1, and press OK.
BE CAREFUL IN THE REGISTRY!! AS YOU CAN CORRUPT YOUR ENTIRE WINDOWS INSTALL!
DO THIS FIX AT YOUR OWN RISK!
Posted on Mar 03, 2008
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
Tip
How To Clean Up Your Computer
Everything in life needs maintenance, and your computer is no different. Everything you do and see on your computer takes up space. Over time, heavy use can start to weigh it down and make your pc run slow. What can you do when your computer becomes cluttered and slow? That's easy! You can clean it up and reorganize the stored files for optimal performance.<br /> <br /> The first thing to do to clean up your pc is to run "disk cleanup". Disk cleanup is a program that deletes clutter and creates more useable memory. If you are using Windows Xp, you can find disk clean up by clicking on "start", then "programs" and "accessories". Then slide over to "system tools" and click on "disk cleanup".<br /> <br /> After clicking on disk cleanup, your computer will display a message that says it is calculating how much space can be recovered on your "C" drive. When it is finished, you will see a screen that shows choices of files in which to purge on the left and the "ok" button on the bottom. Click on every box that is available and choose ok to begin cleaning your disk.<br /> <br /> This process can take a while, depending on how long it has been since the last time you cleaned your computer. When its finished, the program will have removed all unnecessary files to free more memory space. But we are not done yet! There is still one more program to run the complete the process and leave your computer running at its best. That program is called "disk defragmentor" and its found in the same place as disk cleanup.<br /> <br /> To run disk defragmentor, click on "start", "programs" find "accessories" and then choose "system tools". Click on disk defragmentor and a window will open asking which drive you wish to defragmentate. Choose your "C" drive and then click "ok" or "defrag" at the bottom.<br /> <br /> Disk defragmentor reorganizes files to bring all of your free space to the front of the drive where it is needed most. <br /> <br /> Running both of these programs once every couple of weeks will keep your computer at its best.
on Mar 29, 2011 | Computers & Internet
Low disk space on Vista Home Premium
hi this is kamal,
pls try to format your system and install windows file in your c drives and this problem will not come again./
if it comes so pls let me know
regards
kamal singh
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
Low disk space
If you are using windows as your o/s; open the control panel, click on performance & maintenance, run a disk cleanup then defrag your drive. The recovery bar red means that the space allotted for recovery operations is very low. Hope this helps & please remember to rate my answer. Thanks.
Jan 26, 2009 | Dell Inspiron 530 Desktop Computer
Low disk space on recovery H disk
Have you emptied the internet files? Go to tools on the toolbar, the go to options and empty temporary internet files. Run disk defragment from the start button when you are done.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
I have a Compaq Presario F700 laptop. It was telling me I have low disk space on Presario_RD (D). I have already deleted alot files and programs and I have also did a disk cleanup and ran the disk...
"low disk space on Presario_RD (D)"
This looks like you are running low on disk space on your D: drive, not your C:. If you were deleting files and programs, I bet it was on C:
It is now very common for manufacturers to split the hard drive into 2 partitions, C: for everyday use and a smaller D: partition that hold recovery files to restore the computer to a factory install state. If your computer was set up this way, the D: is not suppose to be used but I have run into systems were backup programs are putting the backup files on D: and filling it up.
You need to find out what is writing to D: and stop it and then remove the files it placed there.
Be very careful with D:, if you remove the wrong files you may not be able to reinstall windows if you have a serious problem unless you have created recovery CDs.
Sep 27, 2008 | Computers & Internet
A problem has been detected an window has shut down to prevent damage to my computer
boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
or
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Dec 14, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
