Question about RCA S1000 MP3 Player
MTP Connected When I plug in my mp3 I get the option to sync with my media player instead of play. And I noticed when I open media player, "usb connected" changes to "mtp conencted".
NOT CONNECTED MP3 PLAYER
Posted on Apr 15, 2008
When I connect my sansa clip to my friends computer it will not play the music on windows media my previouse one just played but this one keeps saying sync to computer
Hey!
Cancel the sync... On Windows Media Player, click on Library - then you should be able to see and play the songs from your Sansa.
If it still fails, change the USB mode within the device to MSC (instead of MTP)....
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Mar 27, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
How do i add and take music off
take the usb cable that came with your player, and plug into your computer and your player, After you plug in the player set it to MTP instead of USB, by using the top right button. Windows will ask what you want to do, select sync with windows media player. once wmp is open, go to your sync tab abd drag and drop music into the mp3 player pane, when you have all the music you want or you are out of space, click the "start sync" button at the lower right. Helpful hint "make sure all files are the same type, mp3,acc,wma.... you will fit alot more songs on the player."
Then if you want to take off only a few songs, just plug in the player and start Windows Media, select your mp3 player from the list on the left, the just left click to hi-light the song and press delete on the keyboard, click yes if asked "are you sure you want to delete"? Or you can format if you want to start fresh.
Mar 05, 2010 | GPX MW-3847 MP3 Player
Well i try to sync music to it and it stops on the first song and take forever to sync. the first song stays at 100% but does not go on to the next song at all
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa c150 MP3 Player
I have a Transcend Tsonic 850 mp3 player for about 5 months now. Until 2 days ago it worked just fine- it opened all files, it turned off and on normally, I had no problems with it. Then 2 days ago I...
When you switch on the Music Player(MP), go to settings->MTP
Under MTP, you can able to find two options, USB and MTP. It will be in MTP, select USB. Now you can able to play with the Player.
Cheers...!
Mr.Maduraikaran.
Dec 13, 2009 | Transcend T-Sonic 850 Digital Media...
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
When I go to sync music from Windows Media Player, it says "It is not possible to change sync settings at this time. Try again later." What can i do to get it to work?
If you normally create a profile for your GPX on your desktop computer. Delete that profile, and then add back your GPX to your computer via the cable and it should work. I presume you are using windows XP?
Aug 14, 2009 | GPX MW3837 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
Mp3 player keeps getting SYNC notice
For NS-DA1G and NS-DA2G: If you are receiving a SYNC notice, your DRM media license has expired. If you are using a media manager like Best Buy Digital Media Store or Windows Media Player. you will first need to authorize the player as an MTP device (device authorized to play Digital Rights Management song files) and then re-acquire the licenses for the tracks. There should be a button that allows this function in your media software.
If you want to remove your DRM tracks, got to:
MENU - Settings - USB - File & Folder
This puts your player into Mass Storage Mode. Once in this mode the player will act like a USB drive and you can navigate to and delete your unwanted files.
Dec 04, 2007 | Insignia NS-DA1G MP3 Player
RCA S1000 MP3 Player Logo
121 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
