Toshiba 2141tb tuning
Hi.
I have an old faithful tv TOSHIBA 2141TB but no manual. I have figured out how to tune the channels in using the remote but do not know how to store the programme to the channel.
Can anyone help??
Thanks
Desperate Donna
  • Donna Jardine
    Donna Jardine Mar 03, 2008
    Hi Pishta
    Thank you for your quick reply. It is actually sky that I am trying to tune in. The only way I know how is via the remote control. I have tuned it again on channel 3 as you suggest but it still didn't store. I know it's going to be something really basic but I just can't figure it out.
    Any further ideas would be gratefully received.
    FYI... I am tuning by pressing the scan button (rectangle picture with a vertical line through in top left of remote) then scanning by pressing the volume up button - if this makes any difference whatsoever??? ...
    Thanks again
    Donna
  • 594 Answers
There is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
Posted on Mar 03, 2008
  • Steven Wander
    Steven Wander Mar 03, 2008
    Do you have an external antenna plugged in? Is it coaxial cable from a wall jack? Sometimes that jack is only CATV. Is it going through a VCR? If so, you need to turn the VCR OFF becasue if its ON, the VCR puts everything on Ch3 and uses its own internal tuner to modulate all content to Ch3. if not, you need to make sure the TV is looking at the :"off air" or "antenna" input and frequencies, switcheable by the input button or antenna select button. I am unfamiliar with SKY, must be a Euro thing?
SOURCE:
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
Toshiba 19DV500 b will only pick up BBC1, BBC2, ITV, C4, C5 no freeview channels. there is no reset or reinstallation options
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
Feb 09, 2011 | Toshiba Televison & Video
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Jan 02, 2011 | Toshiba 27AFX54 TV
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
I have a Toshiba TV model 2141TB and have lost the manual I am trying to get it into AV mode to add a free view box can you tell me how to do this ??
There is usually a "source" or "input" button on the remote and/or the TV that when is pressed will cycle the television thru different inputs. Just stop when you get to the AV mode you have the box hooked up to.
Sep 13, 2009 | Televison & Video
Tune in remote to Toshiba Tv
you cant tune a difernt remote to a differnt tv but what you can do is take it back to the place that you brought it from and see if they can give you a refund and i would buy another tv. sorry.
please rate my help to you.
thank you.
Apr 25, 2009 | Televison & Video
Can't set up a magnavox ZV457MG9
What it really means is set your tv to the channel that displays the VCR/DVD palyer
Jan 24, 2009 | Toshiba DVR660 DVD Recorder/VCR
Toshiba 2151TB Television
I had a similar problem. You need to press the 2nd button down on the remote 3 arrows should appear on the screen. then use the volume + and - buttons to tune to correct channel. once the correct channel has been reached you need to enter the number of the channel u want stored ie 03. Hope this helps.
Sep 07, 2008 | Toshiba Televison & Video
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
397 people viewed this question
Top Televison & Video Experts
Ekse
