Question about iLO DVDR04
No eject/reads hello thats all
Tray will not eject cd and when you turn it on it reads hello thats all
  • 1 more comment
  • welov03 Mar 03, 2008
    I looked at the bottom and there is no hole to put the paper clip in,have any more idea's ?
  • welov03 Mar 04, 2008
    Do you have to take off the front face cover to get to it ?
    Thank you for your help...
  • 593 Answers
Is there a small hole under the tray? Use a straightened paper clip and piu it in there and push, it should manually push the tray out. If there is anything on the DVD that looks like a computer program, the DVD may be trying to read it as a BIOS upgrade. The spindle motor may be bad too as the DVD is waiting for the platter to spin up to read it and is timing out.
Posted on Mar 03, 2008
  • Steven Wander
    Steven Wander Mar 03, 2008
    the hole is right under the tray and the paper clip would push in parallel to the tray. If you follow the bottom lip of the tray bezel, is there a little place that a paperclip would fit into? That is my only suggestion. Most PC CD-ROM's have this little hole.
  • Steven Wander
    Steven Wander Mar 04, 2008
    other than surgery, which is very easy on these, just remove the screws and the whole top comes off. You should be able to manually eject the tray. They are pretty simple inside, maybe 2 boards and the loader.
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Releas a disc from cd player
If you can find a pinhole somewhere on the front underneath the cd tray.that usually is where you can push a fine needle or paper clip to manually open tray if there isn't one you should try turning off ignition and whilst holding the eject button turn ignition back on without releasing button.if that fails you will have to dismantle the cd unit from dash.the laser can get condensation in certain environments and fail to read or cancel.hope some this is of help.
Feb 01, 2015 | 2003 Saab 9-3
How to eject cd, no tray, just a slot
You can eject it by going to computer. Then look for the cd drive letter. Right click on it and look for eject.
David
Mar 26, 2013 | Samsung NC10-14G Notebook
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
iLO DVDR04 Logo
111 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
