Question about HP LaserJet 2840 Printer
When you print it cimes on 50.1 fuser error and won't print
Have a HP lasser jet 2840 and when you try to print it comes on the window 50.1 fuser error and won't print
  • rox7 Nov 06, 2008
    50.1 fuser error.
    How do I correct this error?
  • 87 Answers
Your fuser lamp is not coming on. Reseat the fuser. If that does not help, your fuser will need to be replaced.
Posted on Mar 08, 2008
I had a problem in the printer saying that 50.2 fuser error that i can neither print, nor xerox & nor scan also. what can i do now?
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Sep 06, 2010 | HP LaserJet 2840 All-In-One Printer
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
The hp color laser jet 2840 does not print. message "50.2 fuser error" appears
HP recommended checks: 1. adequate 120 VAC power supply, 2. Remove Fuser Assembly, wait 5 minutes and then reseat. 3. Reset the printer to Factory Default settings (remember to copy down the IP address, mask and gateway numbers first).
While this may solve the problem, it is much more likely it's time to replace the fuser. Cost is approx $125 if you buy it online. Just do a Google search on HP 2840 fuser.
This link will show you where your fuser is and how to remove and replace it.
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=445194&MEID=631309C6-088F-43F9-931F-604BAE10EB69
Oct 21, 2009 | HP LaserJet 2840 All-In-One Printer
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
Aug 14, 2009 | HP LaserJet 2840 Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
50.2 Fuser Error in HP Laserjet 2840
Printer connected straight to wallsocket,?check the fuser, remove it check for damages, and put it back, if error persist buy a new fuser.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP Laser Jet 2840 50.2 Fuser Error
Usually this means that the fuser is not heating to the correct operating temperature. Remove the fuser and check all contacts. Be careful it can be very hot. Always let it cool down for atleast 30 minutes before touching the face of the fuser. After you check it over and clean off any contacts, reseat the fuser back into the printer. Plug it back in and turn the printer on. If this doesn't work and you still get the error, the fuser needs to be replaced.
Apr 12, 2008 | HP LaserJet 2840 All-In-One Printer
2840 printer 50.1 & 50.2 error dometimes 13.0 error
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
Dec 14, 2007 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Printer Logo
193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
