Xerox xc830 Every time I try to print the paper jams about halfway thru at the final rollers. I have tried cleaning and different paper. Thanks for any help.
  • shaggy calf Mar 03, 2008
    Bingo!!!!
    Thanks for the super fast and super accurate diagnosis. The gear, which is black and on the end of the long grey roller, has partially disintegrated with most of it still in place. I would very much appreciate if you could let me know where to find the replacement.
    Thanks again
    Wonderful,
    Thanks again.
    President:
  • 2,072 Answers
If it is making it to that final roller area, the fuser gear is broken.
I would almost bet my house that if you look toward the back of the machine, you will find the gear laying in the bottom of the machine in 3 or 4 pieces.
I am assuming some things here.
1 is that the paper is not damaged, and you are talking that it has just entered the heat roller area.
Easy gear to replace, it is on the back of the fuser assembly, you can locate it, by going all the way to the inside ( back) of that fuser assembly. CAREFUL it will be hot if the machine is on, And on the upper roller, normally gray, it should be on the back side.
Let me know if it's a problem I can give you a place to call and order it. If I rememeber correctly it is in the $15 range.
Posted on Mar 03, 2008
Printer does not move page fully thru rollers.
Rollers may look good but it sounds like they need to be replaced. You will need the separation and pick up rollers.
Printer Repair Service in Miami and Fort Lauderdale FL
Jun 06, 2017 | Dell 1600n All-In-One Laser Printer
HOW CAN YOU STOP CONTINUOUS PAPER JAMS. TRIED DIFFERENT WEIGHTS OF PAPER AND NOTHER HELPS. WILL PRINT FINE SOME TIMES THEN IT WILL JAM SEVERAL TIMES IN A ROW.
The most common thing for paper jams is when the paper pick up roller is worn out. It's under the machine where the paper try is ,you can try cleaning it with goo-gone it's a substance that removes bubble gum but it does the trick but I recommend you switch those rollers to new ones just to avoid cleaning it every number of pages.
good luck.
Dec 18, 2009 | Brother HL 5170DN Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer will not print
Hope that helps!
PREM
May 26, 2009 | HP PSC 1410v All-in-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Jamming halfway thru fuser
WHAT IS THE JAM / ERROR CODE
ARE THE PAPER TRAYS REGISTERING THE CORRECT PAPER SZ. LTR OR LTR R LGL LEDGER ECT...
Jan 27, 2009 | Minolta CF2001 Copier
Canon Pixma MX310 Office printer. continues to jam paper. in the maintenance panel i cannot perform an alignment check or deepclean. Attempt to copy feeds a whole sheet thru and chokes on the 2nd piece. I...
Printers that jam usually have worn feed rollers, some where in the machine, or a bad sensor. If worn feed rollers are the problem the paper usually jams in different locations in the machine. If a sensor is bad the paper usually jams in the same spot each time paper is fed into the machine. A new machine does not have worn rollers, but could have a broken sensor. It sounds like the a roller might be worn. There is a company called Tech Support that use to sell a cleaning fluid for paper feed rollers. You can use alcohol but alcohol dries out rubber, but you can use it to diagnose the problem. Clean all visible rollers. Especially the rollers that the paper jams between.
Nov 20, 2008 | Office Equipment & Supplies
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
162 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
