Question about Linksys Wireless-G WRT54G Router
Wrt54g I have two computers hardwired into the router and would like to setup wireless for a playstation 3 how do I go about this? Thanks for your help.
  • Fluffmeister Mar 09, 2008
    Thanks for the link a67994. Everything is working great. My only concern though is the signal strength to the PS3 . Getting at best about 65 percent. The router is about 30 feet from the PS3. Do I need to be concerned about the signal strength. I was told that the strength should be at least 80 percent. Maybe this is not a big deal.Thanks again.
    Fluffmeister.
    Problem Solver:
  • 8 Answers
On the WRT54G the Wireless Should be on by default as
SSID: Linksys less its been changed for some reason on yours
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Posted on Mar 04, 2008
  • a67994 Mar 04, 2008
    The end of the link should be
    settings/connectwireless.html got cut off.
I accidentally disabled my wylan. how can i get it back or enable it?
You need to hardwire the computer with any of the LAN port of the router. Then you need to log into the user interface of the router. Then you need to click on the Wireless tab and over there you may turn on the wlan of the router. Accessing the Router'sWeb-Based Setup Page
If you need any help then you may chat with some technician available at this website.
Jul 10, 2011 | Linksys Wireless-G WRT54G Router
Hardwire ports on wireless router not working
You could
1) Reset the router to factory default by hitting the reset on back
2) You could visit the router over the wireless link (http://192.168.1.1) default password is "admin" username blank.
Check on the page to ensure the ports are enabled.
3) Update the firmware on the device. see if it works.
Note there is a port called "uplink" which is designed for the internet connection and not the local computer.
Jul 22, 2010 | Linksys Wireless-G WRT54G Router
My hardwired computer gets on line but the other two wireless can't. I've reset the router several times but no luck. Checked all the connection still no luck.
Check if the router is assigning IP addresses to the Wireless devices. Also se if you hard-wired desktop has been assigned an IP address manually. Else try to assign IP's to wireless devices manually (Depends on your setup)
Please rate if helpful.
Thanks
Apr 14, 2010 | Linksys Wireless-G WRT54G Router
Hi, I can't get my wireless work. I tried to reset it. But it still not work.
Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 06, 2010 | Linksys Wireless-G WRT54G Router
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
Had problems changing router settings/setting up security info
in your internet browser type the address
198.162.1.1
that will take you to the setup page for your router.
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
Wireless not working
it sounds like you are not setup to go wireless Make sure you run the cd that came with the router so all setting are saved correctly on the router you will need to be hardwired to setup the wireless and the cd will prompt for you to unplug the cat cable. make sure that your wireless is turned on my going to start - settings - control panel - system - and your wireless card should be listed under network adpaters
techsupport@grindstaffscomputerservices.com
Feb 24, 2009 | Linksys Wireless-G WRT54G Router
Wireless set-up
Try a different web browser, sometimes that helps
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
132 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
