Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 paper feed problem
I have a Lexmark X5150 All-In-One and it has stopped taking the paper in correctly. It takes in only the right-hand side which scrunches the paper up. Also, sometimes it shows that there is a paper jam where there is none.
Driver
Posted on Mar 04, 2008
Driver
    Genius:
  • 3,587 Answers
The rollers may be dirty or there is a small piece of paper stuck down in one of the tracks or channels..
Posted on Mar 03, 2008
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Hi, I'm having a paper feed problem. When I go to print it will feed the paper in mid way then stop and no longer take the paper to feed???
Remove all paper.
Check for any particals of old paper and dust in tracks.
Blow tiny dust away or use vacuum cleaner
Insert a little paper.
Go into maintenance mode to check all is working OK.
Try printing normally again.
Jan 03, 2011 | Lexmark Office Equipment & Supplies
X5150 printer turned; no paper in printer; paper feeder continues
Unplug the printer and then open the front and look at the Rear right side and you should see a small ce6913f.jpg
Tab If it is bent then gently with a pencil or pen push it back and try printing if it still gives you problems then contact Lexmark and if you still have a warranty they will replace it if not then you will have to get a new one.
Best suggestion for a new printer that is almost the same is the Lexmark X3550 printer.
Apr 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Nov 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Loading Paper for Lexmark
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Jan 07, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer wont take paper
Yah i have the same problem... Its a Piece of S@#T.  The Lexmark support said to clean the take up roller with a moist Q-tip.  It helps but you need to do it every time you print and it still clogs.
Oct 09, 2007 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
234 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
