Question about Cyberhome CH-LDV7000 Portable DVD Player
Screen is dark
The screen is to dark to see picture - sound works, but there is no picture. This happened once before and we adjusted the brightness, however, this time we can barely see the bar at the bottom to fix it. Can you help?
  • 579 Answers
If it uses the same technology as a laptop screen, there is 2 backlights behind the screen, they are like very thin fluorescent tubes (cold cathode) and there is a power supply that these use. It may have gone out like many PC's bad displays. I think it is due for replacement or an operation if you are skilled enough. Might just be an unseated ribbon cable which can be fixed by yourself.
Posted on Mar 03, 2008
Dark picture w/ good sound. i also tried to adjust the screen and focus at the back of flyback but its too dark
If you cannot adjust the picture brightness with the TV set control(s) then it is likely the tube is failing and you will need a new TV.
Nov 18, 2015 | Televison & Video
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Screen is really bright on dynex dx-l42-10a. Still show picture but bright no matter how it is adjusted. Was fine while watch TV & picture just got bright like the darkness quite. Any suggestions & what...
Sounds like screen voltage has exceeded much. Its LOT adjustments should be checked. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 25, 2014 | Televison & Video
Beko tv nr32wlu520hd
Try to adjust the screen voltage a little up. It sounds that either screen voltage has been gone low, or the sub brightness setting have some
fault in circuit. fe77881c-4dbc-4d47-a595-af42451bcc4b.jpgSee the screen control adjustment potmeter. It is Attached with line output transofrmer shown above. There will be to adjustment potmeaters, marked as 'screen' and 'focus'. Adjust the screen, the lower one, to a little bit, and try.
May 23, 2013 | Beko Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Picture very dark
try to adjust the screen at the back of the plyback.a big parts inside the tv with a wire attach to the picture tube. thre's a two knob there, the lower knob try to adjust it
Oct 09, 2008 | Sylvania 6432GG 32" TV
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Picture too dark
if u hav a remot for it it shoud hav a screen ajust. ther is a pictur of a sun press it 2 times. if that dosnt work press it agn
Aug 06, 2007 | Panasonic PV-M1349 Combo
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cyberhome CH-LDV7000 Portable DVD Player Logo
163 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
