Question about Maytag MAH2400A Front Load Washer
Washing machine with "nd" code
I tried to wash my clothes today, but 2 minutes later the code "nd" appeared in the machine, I'm living in a rented house, the machine was already here when I came, so I don't have a manual, and I don't know how to solve this problem, if somebody can help, I'll be very thankfull
  • 2 more comments
  • Guilherme Mar 06, 2008
    Hello k1ntar0, thank you for answer my question. Yes, when I turn on, I listen wierd noises that I didn`t used to listen before. The water is not draining, when I open the door, the water is all there, and the clothes are very wet. No, there isn`t excesive amount of suds, just the water.
    Do you know what I can do?
    Thank you again.
  • Anonymous Oct 02, 2008
    Blog is private. Sucks i need this step by step!
  • dpaddle Apr 01, 2009
    same exact problem, need to see that blog but it's private!
  • k1ntar0 May 11, 2010
    "ND" might indicate No Drain. Are there any wierd noises? Is the water draining? Are the clothes still wet? Does it sound like there is anything rattling around inside? Is there an excesive amount of suds when it happens?
    Problem Solver:
  • 5 Answers
Check the drain hose. If it's not kinked or blocked then it could be the drain pump. I just pulled out two rocks from my drain pump. I found step-by-step instructions with pictures here:
http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
Posted on Mar 06, 2008
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
"nd" code on my washer, after I moved residence what would cause that?
Nd = no drain. Either drain pump is clogged or defective. Too many suds can also cause this problem.
Oct 05, 2017 | Amana Washing Machines
Nd code and door locking
There could be another coin in the drain pump, jamming it.
With power disconnected..........Does the pump turn by hand in both directions?
Nov 21, 2017 | Maytag NFW7200TW Front Load Washer
E90 error
The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH2400A Front Load Washer Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
