Question about HP PSC 1315 All-In-One InkJet Printer
Paper sensor have an hp photosmart 8250 and will not print.
  • richardson40 Mar 03, 2008
    got it to print now photo quality is awful
  • 3,587 Answers
Try it on test page print first..
Posted on Mar 03, 2008
My hp photosmart 8250 is displaying error message Automatic paper sensor failed. Will not print, pay runs right through it. Please help how to fix
check this link is from Hp resolution center. i think this will solve your problem.
May 02, 2011 | HP Photosmart 8250 InkJet Printer
When I try to print with HP Photosmart, I get
Hey Cathy,
One of my clients had this problem as well. It is due to your sensors not working correctly. In the tray there are two clips that hold the paper tight, keep trying to adjust those clips and this should solve your issue. However, if this does not solve your issue - you most likely have a hardware issue and parts will need to be replaced.
Jul 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing from Elements 6 w/ HP 8250, image pushed to left.
I wish I did have a solution. Photoshop Elements 7 exhibits the same problem. They obviously broke something. I have to use an old version of Photoshop Elements 4 just to print properly. I am a tech support professional, uninstalled all HP software, re-installed latest drivers and problem persists. Sucks.
May 14, 2009 | HP - HP Photosmart 8250 printer
My HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
May 09, 2009 | HP - HP Photosmart 8250 printer
Paper mismatch paper size to small choose a large size
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Dec 12, 2008 | HP Photosmart 8250 InkJet Printer
My printer isn't grabbing the photo paper
have you tried with normal paper..does it still do the same
when you load the paper does the roller sit on the paper at the roller....
but if your machine reports that there is no paper even though the roller is sitting on the paper
turn off your printer//remove the ink cartridge.....get a can of contact cleaner..with the nozzel on..throughy spray the roller area this is where the papper sensor is...
if this still doesnt help you will need to open the printer and check the sensor
keep me posted
Nov 17, 2008 | HP Photosmart 8250 InkJet Printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
112 people viewed this question
Ben Johnson
