Question about Indesit W 123 Front Load Washer
Drum will not turn
My washer drum will not turn to spin the water out. The agitater will turn and the water will drain but the drum itself will not turn in order to spin out the excess water.
  • 121 Answers
Check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Posted on Mar 03, 2008
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Washer 22632 sits and clicks continuously after draining
You'll need to unplug the washer and then remove the hook end of the drain hose from the drain itself. Lower the hose to a bucket until it starts pouring water and empty the drum in this way. Next turn off and disconnect the water supply lines. Put a piece of carpet or a doormat on the floor and lay the washer on it's side.You'll still have a small reserve of water to contend with using a mop but it won't be overwellming.Check the drivebelt for signs of wear and or breakage. Turn the large pulley in the center of the machine clockwise and counterclockwise several turns in each direction. The motor reverses itself to pump and spin and again to agitate. If these turns prove to be difficult in either direction, you'll probably need a new transmission or a new machine, depending on your mechanical expertise.P.S. remove all clothes to perform the previously described test.Good luck, Dana
Sep 06, 2009 | Kenmore 22422 Top Load Washer
PAV33300AWW -top load washer won't agitate or spin,i can manuallly spin the drum and then it will spin,it drains but not spin ,was making a racket prior to taking out the agitator.any help is greatly...
Best thing you can do is to do one of two things, you can remove the agitater and make sure nothing is tangled on the shaft, but if it goes through the spin cycle thats probably not an issue. or you can take off the outside shell of the washer and visually check the belt and the motor.
May 10, 2009 | Washing Machines
Hotpoint aquarius WMA40S Drum wont turn at all
the drive belt needs to be replaced. if you take it to a home depot or a lowes they will replace it at a cheap price. thank you for using fixya
Feb 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
No agitation
Pump stopped up, something jammed either in the tub or agitatator preventing spinning
Sep 17, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Indesit W 123 Front Load Washer Logo
171 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
