Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Convergence off I have a phillips 51pw9303/17f and i cannot adjust the convergence it is off and remote wont adjust it? I went to menu and went to convergence and it just wont change it?
  • 8,596 Answers
The convergence board is bad. If the convergence board were still good, then the convergence menu would allow you to adjust the crosshairs.
Posted on Mar 04, 2008
How to adjust the convergence setting in a phillips model 60pp9401 tv
Use your remote and goto the convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jun 14, 2011 | Philips 46PP9302 46" Rear Projection...
Cant adjust convergence on phillips magnavox tv remote makes sensor flash but crosses wont move
Install the convergence repair kit. www.tvrepairworld.com has them for most phillips models and the kits also contain the CD with instructions.
Nov 26, 2009 | Televison & Video
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Suddenly the blue and red went way out of convergence and the picture is bowed, like upwards.. when i try to adjust convergence with setting and remote nothing moves
The Phillips DPTV305-DPTV345 convergence repair kit should fix the issue. The kit is avialable at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color convergence on our Phillips 46999302/17F
If you are not able to adjust the convergence using the remote you need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Example: RED moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 43pp92 0217
Sorry to bother you again but I did some research and the chip numbers are STK 392-120 but using STK 392-180 is recommended replacement. If the picture is bowed or skewed any at all then the chips are needed replace both and check if any 6.8 ohm resistors are burned or open. Resistors Can be measured out of circuit with a digital volt-ohm meter. Have you tried the consumer menu and located the convergence adjustments? If it only need touch up you should go there. And the numbers I gave you 062597 must be followed with pressing the status button on the original remote. this goes into the service menu and adjustment to convergence can be made there also if touch up is needed or after you replace the chips Hope this helps
Dec 30, 2007 | Televison & Video
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
290 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
