Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
External not being recognized
So i was in a hurry and was plugging things in, when i realized that i plugged my ASUS battery charger pack into my power port for my external, its lit up, for about 3 seconds then went off, i immediately disconnected and tried plugging in the right power cord for the external and its not being recognized or even turning the thing on, any suggestions?
  • joelhare Mar 03, 2008
    ASUS AC adapter
    Model number for AC adapter -ADP~120ZB BB
    Input~ 100-240V ~ 2.0A 50-60Hz
    Output 19v - 6.32 A
    External Power plug\
    Model Number for External WA-24C12U
    AC Input~ 100-240Vac, 50-60Hz
    .55A Max. 50VA-80VA
    DC output~ 12Vdc-2A
    As to the positive/negative rings, not really sure on how to check that, anything else you need
    I kinda figured that, but was hoping for a miracle cure, since i am deployed i guess i have to buy a new one, thanks for your help boss!! I appreciate the timeliness of it and info.
    Genius:
  • 3,587 Answers
Can you tell me the power/current ratings, for each of those power packs, and also, make sure that the ring configuration(positive/negative) are the same?
Posted on Mar 03, 2008
  • Patrick Michaels
    Patrick Michaels Mar 03, 2008
    nope..you may have over voltage fried the drive. The voltage issues are MAJOR for these..current not too big of a deal..that thing under warranty?
    to recover, you'll need a specialist in these things, in your area. Not easy, and not too cheap either.
    sorry to be bearer of bad tidings.
    I use an online backup service, that works just fine.
    see it here
  • Patrick Michaels
    suggestion for next time..color code the plugs with different color tape or markings, so that when reaching behind, it's obvious which is which.
    thanks for using Fixya..
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
Asus1000ha flashes between AC Mode and Battery Mode
Based on your explanation I will try to answer your problem.
It seems you have a problem with charger regulator. When you plug your charger into AC outlet then this regulator will detect the current that flows through voltage sensor then the Vreg pole will command the regulator to open charging circuit.
In plain English: Your computer has a problem with power regulator IC which located near the battery poles.
Aug 11, 2017 | ASUS Eee 1000HA PC Notebook
My lptop battery is stuck at 40 % charging, but in fact it is only on external power nd the moment i switch off the plugs, laptop shuts down
bad news; if its reading 40% with the power cord, its most likely the battery pack... if you're not seeing strange troubles while the cord is plugged in, then its probably not a bad charger. this isnt GOOD news, but try just removing the pack, and then plug it in... if its still working, then you found the problem... and the "charging" icon should disappear, leaving only the "ac power" indicator - good luck
Dec 11, 2010 | Toshiba Computers & Internet
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
Oct 20, 2010 | Pride Mobility Products Go-Go Elite...
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
ASUS P4S800 motherboard - USB2 hubs
Check you bios and make sure that P&P(plug and play) O/S is set to enabled.
Apr 12, 2008 | ASUS P4S800-MX Motherboard
Battery charging
I was charging newly purchase camera for hours, then I realized my battery was in upside-down. It took approx 2 hours to fully charge once I fixed the battery install!
Dec 03, 2007 | Jazz DV-179 Digital Camera
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
125 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
