Question about Samsung ML 2010 Laser Printer
Fuser Error Hy therem, I`ve sust bought a new Samsung ML 2010, I`ve installed it, and when I was trying to print a test page the monitoring software of the printer gave me this : Fuser Eroor.. What can I do ?
  • 818 Answers
You must change the fuser.
Sergio
Posted on Mar 03, 2008
Hello I cant instal my Samsung ML 2010 Laser printer on my laptop using Windows 7 64 bit. The problem is in instalation - argument invalid or somethink like this error Please help me i need this...
Try downloading the latest drivers directly form Samsung. The link is below, at the top of the page click Driver, and on the list (right hand side) click the icon for Universal Print Driver. I would save the file to an easy to get to place (i.e. the desktop). After you download it, run it.
http://www.samsung.com/us/support/downloads/ML-2010
I hope this helps and solves your issue.
Jul 22, 2011 | Samsung ML 2010 Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
My printer has a on line error how do i fix it
Your printer comes with a software monitor called "Smart Panel". It installs automatically when the drivers are installed, unless the user specifies not to. I need you to right-click on the blue "S" shaped icon on the lower-right corner of your screen (assuming it is installed) and check if any error message is displayed. However, the most common problem for such little printers is that the fuser unit blows away with the slightest disturbance in power. If the unit is under warranty, the fuser is covered. If not, prepare yourself to get a new one, since the cost of parts and labor usually exceeds the purchase price.
Be blessed.
Apr 15, 2010 | Samsung ML 2010 Laser Printer
I've just downloaded and installed the printer driver for my Samsung ML-2010 on my MacBook (OS X 10.5.6). The printer is working, when I do the test page, it prints fine. But when I ask it to print from...
Are you sure that it is your default printer if not try this :
1. From the print dialog, choose Edit Printer List from the Printer pop-up menu.
2. Select a printer from the Printer List.
3. Choose Make Default from the Printers menu.
In the Printer List window, a gray dot marks the default printer.
Then try again
Jan 04, 2010 | Samsung ML 2010 Laser Printer
Samsung ML-2010 prints test page but doesn't recognize from programs on laptop
tHIS MAY be a problem of the software. or if the printer does not recognise on any PC then the problem in the main board of printers.
Nov 14, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Need to know how to install printer
Hi!
Please download drivers for printer first at driverguide.com or download.com without connecting the printer yet.
After installing drivers and/or software for printer, restart PC and then connect printer. Print test page to test functionality.
Thanks and good luck! =)
Jan 04, 2009 | Samsung ML 2010 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Stopped printing after I installed new Toner!
If the new toner is original, your unit just burned the fuser. If it is under warranty, any Samsung Authorized Service Center will gladly replace it for free.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
382 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
