Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold refridgerator light not working and is making funny noise
The light is out, on fridge side not freezer, makes wierd noise when you open fridge, but is keeping food cold, and the tempeture gadges arent lighting up
Interesting, might light on the refrigerator side went out too. There touchy in that if I put the bulb in all the way it will knock the temperature control lights out too. I've discovered the 2 bulbs behind the second crisper in my Whirlpool conquest were blown, replaced them and still none of the 3 refrigerator lights comes back on. Still looking for solutions.
  • 14 more comments
  • NotMuchHelp Mar 12, 2008
    Whirlpool Gold side by side (GS6SHEXNB00). Came home to the same symptoms: opened the refrigerator door, one noisy flickering lightbulb (other two burned out). No display on temperature control until I unscrewed the flickering lightbulb. Sound goes away when lightbulb removed (assume voltage issues causing noise in bulb)?
    Refrigerator cooling still seems fine. Freezer still working properly, cooling is fine, icemaker is working, lights are okay.
    Will be contacting service company for solution.
  • Orlando5 Mar 16, 2008
    I have the same problem. The freezer light is on, the refrigerator lights and display are off. I took of the module only to find the bulb is still good. I purchased a book on-line but it is a generic whirlpool book and does not cover this area.
  • Anonymous Apr 13, 2008
    I have same problem with my fridge. Please post if you find that it is the control board.
    Came across the same problem. Went to open the fridge and the light was outonly on th e fridge side not the freezer side, it wasl also making a clicking noise. so I pulled the fridge away from the wall and listened. Then pulled off the bottom cover and traced the sound to the circuit board. One of the little black things on there was clicking so I have come to the conclusion that it would probably need to be replaced. I priced the board at $118 and now I'm shopping for a lower price and getting input from other people with the same problem.
  • Anonymous Apr 19, 2008
    4/19/08
    I have the same problem. The freezer side is working properly and the refrigerator side is cooling but the lights on the control box and the refrigerator door lights no longer work.
  • Anonymous Apr 22, 2008
    Our refrigerator also started having this same problem yesterday. Light doesn't work, and there's a clicking sound towards the bottom of the unit. Also, the light bulb is fine, and appears to flicker very lightly with each pulse that you can hear.
    Is Whirlpool covering this problem?
  • jecha May 23, 2008
    Same problem, control light & top light don't work, but still cooling.
  • Anonymous Sep 11, 2008
    same problem! whirlpool should at least pay for a portion of the cost to repair it.
  • bearhunter1 Oct 09, 2008
  • Anonymous Nov 06, 2008
    tech says i need a new circuit board. this will fix the light problem and the freezer leaking water. it is only three years old. we are disappointed.
  • haxczar Nov 11, 2008
    Exact same problem, open the fridge and get buzing with flickering lights. playing with bulbs got one or 2 but not all three working - but only flickering, buzzing sounded to me a lot like arcing, also nasty plastic smell like brand-new fridge plastic smell but much stronger indicated something hot. After opening and closing the door a few times trying to find the problem buzzing stopped but so did compressor... Freezer lights still worked, but all cooling stopped; luckily we have an old fridge / spare freezer so we could transfer almost all of our food to save it. pretty certain this is shorted main control panel. Fridge less than 3 years old - very disappointing
  • Anonymous Jan 19, 2009
    Same problem about 1 year after fridge was purchase. Now (2 years later) the board went again.
  • Travis Reinert Feb 07, 2009
    Whirlpool side by side refrigerator light will not work. the lights in the freezer side work. ensured new light bulb works, took out door switch and it seems good, have power to switch what is left?There is a irratic clicking sound coming from the lower right bottom of the fridge only when the fridge side is opened. The light does not come on and the LEDs on the controls do not light up either. The clicking goes away when the door switch is pressed. The freezer side light works fine. The fridge/freezer are cooling fine. Sounds like a bad relay???? Any help would be great!
    Thanks!
  • 1f2frfbf Apr 19, 2009
    Same problem. Whirlpool products are garbage. I have six Whirlpool appliances that are all less than five years old. Of the six appliances, I have had issues with five of them. If you call Whirlpool you will get no joy, their staff is surly and rude. What a disappointment.
  • Gary Davd
    Gary Davd May 11, 2010
    you may have a short in the display board dissconnect the wires in the disaplay see if the lights work and vice versa
  • Larry Gold Jun 27, 2013
    It is the main board found at the back of the fridge on the left side when looking from behind or right side when looking from the front. it is in a cream coloured box attached to lower side at back. replace it and should solve the problem.
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
  • Megan W
    Megan W Jul 20, 2017
    Good Morning! The main control board for this model is no longer produced. But, Don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. http://www.fixyourboard.com/boards/W1013...
Mine started doing the same thing this the day before yesterday. The lightbulb on the fridge side went out and it started making the noise everytime we open it. It was purchased in 2004 (5/04 manufacture date) model # GD5RHAXNT00 and is a Whirlpool Gold. Had to have the ice maker replaced in March. (it went out last year)
Posted on May 28, 2008
Does this qualify as normal "wear and tear?" I've had my conquest gold for less than 4 years and the board's gone out and we have a repair man at our house that whirlpool recommended quoting us over $300 to repair it! unreal...i could imagine if it was something that the consumer used every day but a RELAY BOARD?! what's the life expectancy on a RELAY BOARD for whirlpool? less than 4 years? chances are i won't be purchasing whirlpool anymore! anyone have any ideas?
Posted on Apr 25, 2008
Your issue sounds the same as mine. I have a Whirlpool Gold side-by-side. The fridge lights don't work.
Appliance Repair guy came today - after testing everything came to the conclusion it's the electric "computer board" that controls everything. Tech says once replaced, everything will be fine.
Posted on Mar 24, 2009
    Problem Solver:
  • 5 Answers
Hello:
Had this same problem - started last night. I found about 60 postings on diychatroom.com about the same problem. What seems to be happening is that the control circuit board gets a trace blown due to a bulb burning out. This is a faulty design, and whirlpool should be paying for the replacement. The control board is around $110.
Posted on Mar 16, 2008
  • Megan W
    New Friend:
It is the main board which is located at the back... on the left if looking from behind the fridge freezer. It is at the bottom of the fridge side screwed to the side in a cream plastic cover. Replace it and the problem should go away.
Posted on Jun 27, 2013
    President:
  • Whirlpool Master
  • 2,651 Answers
If you pull out the refrig, screwed to the cabinet, along side the compressor is a circuit board inside a white housing, theres beena short on that board and will need replacing.
Posted on Mar 04, 2008
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
Posted on Jul 20, 2017
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights out inside refrigerarator and making noises
bad door switch unplug and pry out switch and replace the sound you are hearing are wires burning
Apr 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
8,121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
