Question about HP PSC 2410 All-In-One InkJet Printer
Printer wont work!
When I turn it on the printer shows the hourglass in the display, and chugs for about a minute then turns stops. Off/on light is flashing. Hourglass is not on permanently on display.
Cant see any blockages and printer cartridges look ok, need some assistance please.
  • 1 more comment
  • barna Mar 09, 2008
    I have exactly the same problem.
  • Anonymous Jun 03, 2008
    hour glass picture and flashing light. I have unplugged and turned off my computer and still the same problem
  • kswils Jun 29, 2008
    my printer is also doing the same the hourglass is displayed on the printer screen and this printer also "chugs" for a few minutes and then does nothing any help or advice?????
I tried everything suggested & nothing worked. Then I unplugged everything from everything, including the phone jacks from the printer & wall & let sit for 24 + hours. All is back to normal.
Posted on Jun 18, 2008
  • 3,587 Answers
Get new printer drivers here first
install, then run a test page with printer disconnected from computer..
if that works, then reconnect printer to computer. should 'see' it, and proceed..
Posted on Mar 03, 2008
/usr/libexec/cups/backend/lpd failed
This sounds like a printer issue rather than something wrong with your Mac. When you refill your printer ink cartridges the ink level setting won't change, and if you let the ink level go down too far before refilling the printer marks the cartridge as empty and locks it out. (something like that)
Try this... It should work on most newer model printers.
Shut down your Mac. (important) Turn the printer off and leave it off for one or two minutes. Turn it back on and wait until it goes through all of its whirring and clicking and chugging start-up noises. When it's quiet you should end up with a flashing "E" or an upside-down "u" on the display. Find the Reset or Stop button on the printer and hold it down for 6 seconds. The display should clear and show the number "1".
Turn on your computer and print. If it works, you're done.
If that didn't work pull down the Apple menu and choose "About This Mac". If it says Version 10.6.8 you're about to spend $29 because the message "/usr/libexec/cups/backend/lpd failed" was common with that version of OS X, and that was the last version of Snow Leopard 10.6. Click the "Software Update..." button which will open the App Store. Shell out your 29 bucks for Mavericks OS X 10.9.
The only other solution would be to replace "lpd" from a different computer that's running 10.6.7, which is doubtful. (unless you have a backup)
Good Luck!
Oct 23, 2013 | Apple MacBook Pro Laptop Computer with...
I have an HP PSC 2510 that has a permanent hourglass busy symbol showing. When turned off and on there is a grinding noise from the scanner transport mechanism which ceases after about 1 minute but the...
Looks like a faulty gear mechanism in your scanner. It is not able to return to the home position. You could try a hard reset: Unplug from power source and PC, wait about 5 minutes and try again. If the issue recurs, then you will need to take it in for servicing..
Jul 04, 2008 | Office Equipment & Supplies
It wont srart even tho the battery is charged it acts like its turning over but never actully starts it chugs for a minute and dies
well it needs good spark [distributor cap] .it needs fuel check preasure .and the only other thing is a plugged cataletic converter. < was it loseing power before it stopped working . other wise i think its the distributorcap and rotor.
Dec 11, 2012 | 2000 GMC Jimmy
Trouble code C-3B04
[1] Turn off the powerswitch behind the little white cover
[2] Hold down the utility /counter buttom while power on and hold it until the hourglass shows.
[3] After a while the displays shows a trouble reset, press it and you will get ok i result.
[4] Power off/on again.
Oct 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
HP 2510 printer in "wait" mode indefinitely
It sounds to me like the printer needs repaired/replaced as the gears which drive the printer cartridges' belt are no longer aligning correctly. At today's prices, I strongly suggest just replacing the printer as you can get a new one pretty cheap now. Good luck!
Apr 18, 2009 | Office Equipment & Supplies
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Jul 22, 2008 | RIM BlackBerry 7100t
Printer won't work
nine times otu of ten the power hit damage the dc controller borde.
Apr 01, 2008 | HP PSC 2410 All-In-One InkJet Printer
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Unit wont start up after power failure
Answer on Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
204 people viewed this question
Ben Johnson
