Toshiba MV-13N3 Television
Problem for Toshiba MV-13N3 Television
Toshiba television/vcr combination
By Donna S on Mar 03, 2008
I have 1 channel that does not get good reception. Lots of static and picture problems. It's the only channel that i have a problem with. I have tries resetting cable TV channels. Even tried the same local channel without cable. i have tried a new cable wire, but still no luck. Please help.
Thank You!
Comments:
Mar 03, 2008
- I did not want to spena lot of money repairing this TV.
Solution #1
posted on Mar 03, 2008
Somewhat Helpful)
micromaster
Rank: Wiz
Rating: 82%, 758 votes
Also try changing the TV system's selector..
Comments:
Mar 03, 2008
- If you have a converter box, make sure your TV set and/or VCR is tuned to channel 3. Also make sure the switch on your TV that says "Cable/TV" is in the "Cable" position. Make sure all connections to the converter, TV and VCR are secure,
Check another channel it may be a station problem.
Mar 03, 2008
- From time to time, you may experience a problem with your television picture that can easily be fixed. Trying to fix it yourself will save you time and may even save you money on television repair. Please refer to this list before you call your local cable office's customer service department.
  • No Signal from Converter
    Check to make sure your TV channel selected for the proper converter output channel (example: Ch. 2, 3 or 4).
  • Rolling Picture
    Adjust "vertical hold" on your TV set.
  • Picture Leans to Side
    Try adjusting "horizontal hold" on your TV set.
  • Wrong Channel
    Check TV dial and converter for channel setting. Make sure TV is set to the output channel of your converter box or VCR.
  • Snow on Screen
    Check to make sure cable connections are tight, and if you are using a converter make sure the converter is turned on and plugged into a working outlet.
  • No Picture, No Sound
    Make sure TV set is plugged into "live" electrical outlet, and not controlled by a wall switch. Push red "reset" button on back of TV set, if your TV has one. Adjust "brightness" control on your TV set.
  • Picture Shrinks
    Power circuits in your TV set are not operating properly.
  • No Picture/Blue screen
    Check channel setting on converter and TV set. Check listing to make sure channel is broadcasting during this time slot. Wait for TV station announcement of difficulty. Check other channels to compare reception. Check VCR cable connections.
Mar 03, 2008
- Donna, if it's ok with you may i know your cable provider, and the channel you got problem, and also may i know if your are using a decoder..?
Thanks,
Solution #2
posted on Mar 09, 2008
Not Rated)
pincer
Rank: Wiz
Rating: 82%, 177 votes
Good day!
pincer here..
Solution #3
Not Rated)
Gigatech
Rank: Guru
Rating: 87%, 518 votes
Make sure your RF wires are of good quality.(Quad shielded) Also try replacing the splitters you use. Buy 2.4 GHZ bi-directional for digital cable. Or Good 5-1000GHZ blonder tongue splitters for analogue cable. If all else fails you can contact you cable company to check you signal coming into your home. There might be a bad or weather beaten cable causing problems with you signal. Also the will provide you with free cable to replace some of your distribution. Hope some of this helps. :]
Comments:
Mar 03, 2008
- Spelling correction:
Make sure your RF wires are of good quality.(Quad shielded) Also try replacing the splitters you use. Buy 2.4 GHZ bi-directional for digital cable. Or Good 5-1000GHZ blonder tongue splitters for analogue cable. If all else fails you can contact you cable company to check you signal coming into your home. There might be a bad or weather beaten cable causing problems with you signal. (correction) Also they will provide you with free cable to replace some of your distribution. They might even give you new splitters.Hope some of this helps. :]
Solution #4
Not Rated)
IB4G2008
Rank: Wiz
Rating: 82%, 2428 votes
Ok..Donna,
From what I've heard here, you are experiencing a channel 'source' issue, which means that this specific channel, is NOT tuning properly. The biggest possible cause of this will NOT be your set. The tuning device, from your service providor, or something up stream in their system, causes this. I'd recommend you simply call the supplier, report this, and have them come out and check for the trouble.
Solution #5
Not Rated)
issy2
Rank: Wiz
Rating: 82%, 332 votes
hello sir
Comments:
Mar 03, 2008
- Please mention what kind of static n picture problems ur facing, you need to give us with some more description of the problem.
Thankyou
Solution #6
Somewhat Helpful)
ser71
Rank: Guru
Rating: 86%, 656 votes
Picture and sound are out of sync As with all products that contain a digital display, in rare instances, when viewing certain content (e.g.. television broadcasts, video games, DVD), you may notice that the sound and picture are slightly out of sync. This phenomenon can be caused by various factors including, without limitation, video processing within the TV, video processing in an attached gaming system, and video processing/different compression rates used by broadcasters in their programming. You may want to try one or more of the following suggestions, which may help to reduce the effect of this phenomenon:
  • If the TV is connected to an external A/V device (e.g., DVD player, video game system, set-top-box, etc.) always try to use the Color Stream video jacks and corresponding audio jacks or the HDMI input (if available on your TV) for connection to such external A/V device.
  • If the TV is connected to an A/V receiver that has a programmable audio delay feature, use this feature to help synchronize the sound to the picture.
  • If connected to a video game system and your TV has the Game Mode feature (see owner's manual for more information), enable this feature.
  • If you notice this phenomenon only on certain TV channels, please contact your local broadcast, cable, or satellite provider to inform them of this issue.
I hope that this can help you
Comments:
Mar 03, 2008
- have you read it?
If you notice this phenomenon only on certain TV channels, please contact your local broadcast, cable, or satellite provider to inform them of this issue. i dont think that this his your problem but a problem of your local broadcast.
Sergio
Popular Solutions for Toshiba MV-13N3 Television
Questions and Unsolved Problems for Toshiba MV-13N3 Television
Do you recommend Toshiba MV-13N3 Television?
Answer
Answer
I have a Sony Trinitron 27T-S27 TV and today it just went off and won't go back on. What is going... (More)
Answer
i need a manual for a kishu lcd151 tv
Answer
need a user manual for a kishu lcd151 tv the tv is a marks& spencer own brand
Answer
hi, we've lost our remote control for elderly JVC c-vt14ekb tv (traditional old style)now we've... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba MV-13N3 Television:
Top Portable Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Portable Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
