Question about Brother IntelliFAX 2800 Laser Fax
Open cover message
We can fax out ok but occasionally when we receive a fax the fax arrives ok but will not print. We get the message open cover. After we do that the fax machine warms up and the same message appears. The only way to fix is unplug and replug in, but we lose the incoming fax and don't know who it is from.
    President:
  • 2,072 Answers
Several possibilities with that. Trying to think what order to try things.
In your menus or settings, there should be a way to clear the memory. You may have software corruption causing that issue.
If you do a memory clear, you will have to enter your date, time, phone number and company name.
You may have a loose connector to the interlock switch or on the circuit board. You would have to unplug the machine and disconnect and reconnect the connectors.
one of the cover interlock switches itself is defective.
Could simply be one of the covers is just twisted or warped.
Possibly one of the cartridges is not seated and arching, corrupting the memory.
After that, there very much less likely is a bad circuit board, ( very unlikely).
The reason I suspect memory corruption is because you have to unplug and plug it back in to clear.
A faulty switch shouldn't make you remove and reconnect power. But, stranger things happen...
Good luck and let me know whats up. Maybe I can offer more ideas once you check theses items. I know , it's a lot.
Posted on Mar 03, 2008
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
My faxes are not printing. They seem to be connecting but they won't print.
Tips and tricks For the LEXMARK X342N
1) Faxes won't print.
Try this first....
Press <MENU> then <*> <#> on the keypad
Press <UP ARROW> and see "UTILITIES RESET SYSTEM"
Press <CHECK MARK>
and see RESET SYSTEM
Press <DOWN ARROW> and see (FAX NVRAM)
Press
<CHECK MARK> should reset the fax memory.
Try this second....
Press <MENU> then <*> <#> on the keypad and see "SERIAL NUMBER"
Press <CHECK MARK>
Press <DOWN ARROW>
<DOWN ARROW> <DOWN ARROW> and see (ERASE FFS)
Press
<CHECK MARK> should reformat the fax memory.
It will reboot. Occasionally says the FAX NVRAM is bad
when performing the boot-up self-test and corrects the problem.
2) PC LIFE WARNING message
After replacing your photo conductor kit you need to reset the "PC LIFE WARNING" message. With the front toner door open press and hold the red <STOP> until you see the "RESETTING PC COUNTER" message
Mar 15, 2010 | Lexmark X342n All-In-One Laser Printer
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer is showing a system error of oxc19ac3ff ink system failure and will not print receive faxes or copy please advise
I had the same problem & found the solution of HP's website. It solved the problem.
HP Website & solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=1153494
Solution one: Reset the product
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
