Question about Dell 924 All-in-One InkJet Printer
Cartridge slides too far left
I want to change my ink cartridges, but when I lift the printer lid to remove them, the cartridges slide to the far left and I am unable to get to them. How do I get the cartridge to slide back to the center???
Keep your printer on, lift the lid should be right in the center.
Posted on Mar 07, 2008
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
How to change ink cartridge on nx220 printer
Turn the printer on.
Lift the lid, to expose the print-carriage and the print-heads.
Wait a few seconds, and the print-head (holding the ink-cartridges) will slide over to some point where you can remove the cartridge.
Push on the "holder" surrounding the ink-cartridge, to "unlock" it, and gently lift the ink-cartridge out. Insert the replacement, "lock" it in place, and close the lid.
Feb 09, 2015 | Epson Stylus 2200 InkJet Photo Printer
How do I change ink cartridges onEpson Stylus SX425W printer. Apart from lifting the scanner I cant see any buttons to press and the present cartridges wont move along to enable me to eject the black one.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed.
Then, "unlock" the ink-cartridge from its socket, and gently remove it.
Replace it.
Then, "lock" the ink-cartridge into place, and close the lid.
Print a test-page.
Apr 11, 2011 | Epson Office Equipment & Supplies
NEED TO CHANGE BLACK CARTRIDGES, HOW CAN I DO THIS?
Replace it.
Print a test-page.
Apr 09, 2011 | Office Equipment & Supplies
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
I want instructions to change hp psc 1610 ink cart.
Wait 15 seconds.
The print-head will slide to an accessible position.
Press down on the ink-cartridge, to "unlock" it from its holder.
Gently slide it out.
Gently slide in the replacement ink-cartridge.
Press up-and-in on the ink-cartridge, to "lock" it into its holder.
Close the lid.
Print a test-page.
Feb 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
Lexmark X1150 - how do I change ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Thanks.
Nov 18, 2010 | Lexmark C533DN InkJet Printer
Where or how do I open my lexmark 7500 to replace ink
Check for printed instructions inside the lid. :-)
Or, wait a few seconds, and the print-heads will slide to a position where you can remove the ink-cartridges, either by lifting a locking-lever, or by pushing-down on the ink-cartridge to "unlock" it from its "mounted' position. Then, slide/lift out the ink-cartridge.
Sep 20, 2010 | Lexmark X2650 All-In-One InkJet Printer
Forgot how to change ink
Lift the lid that covers the print-mechanism.
In a few seconds, the cartridges will slide to a place where you can easily remove them, and insert a replacement cartridge.
Close the lid.
Jul 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Changing ink cartridge
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
115 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
