Question about Palm Treo 650 Handheld
Palm Treo 650 Wireless headset jack
OK, all I would like is a way to fix my phone so it does not think that there is a headset in the jack when their is not. If I can restore the function of my speakerphone and earpiece I will never use a headset again! Any way to fix?!? Help!!!
    Problem Solver:
  • 36 Answers
Sounds like something got tweaked in the socket. If this is still under warranty I would suggest exchanging it.
Posted on Mar 05, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
I can't hear anything when I call
I had this problem. It appears that the solder joints on the headset jack are rather weak. When they break, the phone thinks there is a headset inserted into the jack, even when there is not. This disables the phone's built in speaker and mic. The solution in my case was to either replace the phone or have it fixed under warranty/insurance.
Apr 12, 2009 | Palm Treo 755p Smartphone
No speaker no sound on my treo
I had to have my Treo swapped once already because of a problem with the headset jack. The same problem is happening now - the phone always thinks the headset is plugged in (even when it isn't). That results in phone ringing (unless on virbate / silent mode) but no audio through the speaker in the back, and no speakphone icon appearing.
Given the symptoms you describe I would go to your service provider and (hopefully) get support under warranty - very likely hardware related.
Aug 10, 2008 | Palm Treo 650 Handheld
Palm treo
THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
Jul 29, 2008 | Palm Treo 680 Smartphone
Lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Apr 24, 2008 | Palm Treo 650 Handheld
Palm Treo 650 doesn't see bluetooth headsets, AND wired headphone jack is shorted
Had a similar problems. Throw out wired headsets with shorting problems. Their too cheap to try and fix.
Try rebooting the phone, then make sure the wireless headset is on. The trick is to get it into "trusted devices", so when you get the phone to seek new or nearby devices, you need to push the button on the earpiece so it sends a signal at the time the phone is trying to find it. It took me a number of trys, but finally got it to work. I use Verizon and they were quite helpful, even though the phone was "out of warrenty". I was re-activating my phone after not using it for a couple of years.
Mar 08, 2008 | Palm Treo 650 Handheld
Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Jan 12, 2008 | Palm Treo 650 Handheld
It's paired up with treo, but when treo rings, the headset will not work.
there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
I recomend a Plantronics brand headset with your phone.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Palm Treo 650 Handheld Logo
80 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
