Question about Lands Phones
Trying to connect jabra to samsung mobile cant find device
Message comes up cant find device????
Took the advice of another person who suggested holding down the button so the blue light is contant. Thanks!
Posted on Mar 04, 2008
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Can you sync a Jabra BT2080 to a Jabra A120?
Hi Bobby Smith1,
Im afraid that is not possible.
the reason is that the Jabra BT2080 is only ment to connect to a mobile device which is used for calls.
and the Jabra A120s is only ment to be plugged into a speaker device whilst connected to a mobile phone.
in fact both the Jabras work like a Normal headset, thus two are not able to be connected. only through a mobile device.
i hope this helps, good luck!
Mar 15, 2011 | Audio Players & Recorders
Jabra hfs001 is not connecting with my Samsung Wireless phone
MY JABRA CONNECTS BUT I HAVE NO VOLUME I HAVE A
T-MOBILE PHONE. I RESET THE JABRA I TURN UP THE VOLUME ON MY PHONE NOTHING
Sep 27, 2010 | Jabra Bluetooth Car Kit with Night Driving...
Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Sep 10, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
I cant do pairing my jabra bluetooth head set to dopod
Turn on your BT125 by presiing button for 4-5 secs
in ur dopod go to settings>communication>blutooth
In the mode tab:check on > turn on bluetooth and >make device visible to others
Then go to devices tab: click on add new devices, your dopod will start searching nereby bluetooth devices...during this time press the button on your BT125 for about 2 secs, it will try to connect to dopod and a message will be displayed : "BT125 wants to connects......" say yes ...it will ask for the passkey enetr 0000 and there you go ...tada
Jun 26, 2009 | Jabra BT125 Headset
Cant recieve text messages
Maybe you never activated the phone to receive txt messages. Call up sprint and activate incoming txt.
Apr 23, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Lands Phones Logo
368 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
