Patton MH761 Utility Heater Logo
Posted on Mar 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red caution light
The red caution light comes on after approx 45 seconds....heater will shut down, then come back on after approx 1 minute....it just started doing this for no apparent reason...heater is approx 3 yr.s old but has very little running time (use) on it.
  • Anonymous Feb 03, 2009
    The heater turns on and off after a period of use even when the thermostat is is maxed.
  • Anonymous Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution!
Anonymous
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Mar 05, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
260011
Points
581
The red light is in conjunction with a safety. This is there in case something goes wrong, the heater doesn't overheat and possibly catch fire. If its not getting too hot, and its sounds like its not. The safety needs to be replaced. It will be a little disc shaped thing with 2 wires connected to it. If this heater also has a tip over safety, there also may be some type of mercury switch too. If you are so inclined, when you find the safety disc it should have some numbers on it. This indicates the temperature it is made to turn off at. After removing it, connect the 2 wires together and turn the unit on with a thermometer in the spot where the disc was. If the temp. doesn't go higher than the #'s on the disc after 45 seconds like you said, then you know positively that is the problem. If it gets hotter very fast, then the elements need to be looked at for defects. If there are no numbers on the disc or you cant find a replacement, then it may just be easier to buy a new heater.
Our Rinnai Avenger 25 automatically switches off within 1 minute. When we press the on button, the unit starts with a green light on the "ON" button but within seconds, the light turns to red and soon...
Did you get any error codes? Press on/off button twice to reset heater or
press both the Up and Down buttons simultaneously for 3 seconds
It can also be a faulty temperature sensor, this would need a service call...cheers
2answers
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
2helpful
Qt9093 heater shuts off after approx 1 min.N
had one one time! lasted for about two years...yes there is a thermo switch, mine was same! heated for about one minute..then off....would come back on after cool down.to replace thermo was like as much as whole unit....crazy I just lived with it! I know this does not fix yours and i'm sorry ...your thermo could be cheaper! check it out
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
45helpful
7answers
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
