1994 rca tv
Rca model:f31700gg (ctc169js6 chassis)the screen went black but the sound still worked fine i replaced the CAPACITOR 35V 2200UF 105C HI TEMP,RADIAL and got 3/4 of the screen back i read on line that it might also be an IC but how can i tell any help would be great
  • 2,336 Answers
Is the screen narrow on both sides of the CRT?
Check HERE for more info.
Download the service manual from HERE.
Good Luck.
Posted on Mar 03, 2008
On my rca 54 tv in the cp150 chassis is a 35v 1800uf capacitor did they change ?
yes they also used a 2200UF 16V for CP150 cap either cap can be replaced with each other and it will work fine.
Jan 31, 2013 | RCA D52W19 52" Rear Projection Television
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Television will not turn on
ON the Deflection board look at cp150 (2200uf 16v)- if it is puffed up on top it is bad replace it and 2 more cp114 & cp120- 220uf 35v. Radio Shack should have capacitors. they are green with gold writing on them.
HAPPY NEW YEAR!
Dec 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound but no picture on RCA R52WH74TV.
You do not have Lamp in this set it is Projection has 3 Tube Red,Green,Blue. On power/deflection board CK capacitor cp150 2200uf 16v look to see if capacitor is puffed up on top if so replace it and 2 other caps in same circuit 220uf 35v they are green with gold writing on them also CK second ribbon connector make sure it is pluged in good.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
ck cp 150 2200uf 16v cp 111 220uf 35v and cp 114 220 or 330uf 35v replace all 3 capacitors
Nov 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA big screen model# D52w20, Chassis# ITC222
Nine times out of 10 the problem is 3 capacitors cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v look at cp 150 if cap is bubbled up on top it is bad capacitors should be flat on top.
Oct 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Oct 06, 2008 | RCA D52W19 52" Rear Projection Television
Help me please
You have bad capacitors 3 of them.cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v
Aug 09, 2008 | RCA D52W19 52" Rear Projection Television
Screen goes black immediately after astar logo screen comes on
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 21, 2008 | Astar LTV-3001 TV
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
