Question about Dell OPTIPLEX GX150 HEAT SINK & COOLING FANP/N 50044D A02
Problem my pc its not have or not find cd rom maybe iiiiiiiiiiiiiiiiiiits problem with bios?????
  • Sergio Scalfaro
    Sergio Scalfaro May 11, 2010
    check the flat cable of your cdrom.
    Sergio
The CD may be turned 'off' in the BIOS listing which you can view on boot-up by usually holding down the F2 key. Sometimes BIOS setting may change for no good reason, so lookout for this and make sure your motherboard battery is providing enough power. Install a new battery if not sure.
Posted on Apr 15, 2008
    Scholar:
  • 101 Answers
Firstly will the CD rom open when you press the button. Is the 4 pin power cable attached to the device inside the case. Old computers have a failing CD before any other part fails usually. If the power and the cables are securely connected then maybe it is just faulty and needs replacing.
Posted on Mar 07, 2008
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
DVD/CD-ROM DRIVE in my PC can't work.
Step by Step:
1) Check your drivers (start>control panel> (Small Item View)> Device Manager
2) Install any missing, or uninstall any unregocnised drivers
3) Check your BIOS for options about turning on and off USB.
4) Test DVD/CD ROM drive in another unit, if it works, it may be the connectors on your motherboard, or even just needed to be reseated. Thankfully re-seating DVD roms on laptops is usually child's play. A few seconds with a screw-driver and you're all set.
Apr 18, 2013 | Computers & Internet
My CD rom not working
check in your bios were it is in the order to boot and yes check your drivers
Oct 30, 2012 | IBM ThinkPad R32 2658 Notebook
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Originally a GX150 but board died and I installed a GX240 board and replaced the connecting cable for the front panel controls (switch etc). Seems to work fine except that it intermittently loses the...
Your problem has nothing to do with the front panel connections. Maybe it's a cd rom's problem, ATA cable problem or bios settings problem. First of all make sure that your drive is set up correctly as primary or slave at the channel. Some motherboards have problems when the cd rom is master and the hard disk is slave. If the master - slave is correct, check the bios settings and, if the problem exists, avoid AUTO settings; change the proper channel at cd/dvd rom.
In case of a problem post me back your drives configuration too (hard disks and cd/dvd rom).
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 09, 2010 | Dell OptiPlex GX240 PC Desktop
Bios not recognizing hard drive and cd rom. usb ports work
Hey I have the same problem, may have found a solution to this problem although im not 100% positive but read My post here in a reply to the same exact problem. Keep in touch with Me on this and maybe we can find a permanent solution
Feb 16, 2010 | Acer Aspire 5050-3371 Notebook
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
I have a Generic External CD Rom Drive and Vista
Can you boot from this external drive maybe you need to set some bios options.
May 04, 2009 | Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Computers & Internet Logo
69 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
