Question about Maytag MGC5430 Gas Cooktop
Pilot Flame is too high.
I need help with Admiral® 30 In. Gas Cooktop
The instructions say that in order for us to adjust it we have to “purge all air from supply system by turning on one top burner valve”.
How do we determine if we purged all air from the system?
How long should we wait until turning the valve off and adjusting the Pilot Screw?
    Novelist:
  • 155 Answers
You will only need to purge air from the supply if this is newly installed or if you have recently disconnected / reconnected the main gas supply for some reason. Otherwise, you can just skip that step.
If you do need to purge the system do the following:
MAKE SURE THE ROOM IS WELL VENTED TO OUTSIDE
REMOVE ALL SOURCES OF POSSIBLE IGNITION
Fully open the largest burner and allow to run until gas is smelt.
There is no way to say exactly how long it needs to be open as this very much depends on the length of pipework feeding the appliance, but in a typical domestic installation, this shouldn't be more than about 5-10 seconds.
Hope this helps,
Matt
Posted on Mar 03, 2008
I want to adjust my Admiral LGC1330AD gas cook top to work on propane. How do I proceed? I'm told there is no conversion kit, it is all adjustment.
Two thing you need to do.
1) Call your gas company where you are supplied propane and ask them to set you up and they or someone who contracts for them will help you.
So you will need to replace ALL burners including the oven.
2) Call Admiral and ask them about changing to propane and if they have the products
Aug 05, 2010 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Kitchenaid 30'' low flame output
It's wasn't the perfect solution but I removed all the burner caps and cleaned each one with a tooth brush. Then using a metal trussing pin, I poked through the flame holes to clean them. Noticed better flame output from both.
Mar 06, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Cant find pilot or maqnual
contact whirlpool to get a manual but be sure to give them the model number to get the correct one / whirlpool owns maytag now ,,,,,,,,,, you can even contact a sears service company to order one since the do the maytag service.
Nov 26, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Maytag MGC5430 Gas Cooktop Logo
169 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
