Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Will not print error
Code 51 on a Brothers MFC-3360c
  • hickssix Nov 18, 2008
    I called Brother and they said it may have been caused by using the wrong weight of paper. Seems odd to me. Any advice?
  • Anonymous Nov 28, 2008
    Same problem, can someone please help? I have no idea why it's saying printer error when i removed the paper jam.
  • 4,041 Answers
Hi Ok try this it may work.
All the best good luck
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
Have error 50 & 51 no paper jams cartridges full
Try uninstalling the software and reloading from scratch. I had to do this although not for these errors.
Jan 23, 2016 | Brother Multi-Function Center MFC-3360c...
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Unable to print 51, Brother MFC-845CW
Error code #51 - encoder strip may be stained with ink, purge cam shaft broken.
Note: error codes for inkjet printers are different than lasers.
Aug 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Print unable, 50 check trouble shooting chapter, I dont have a book, We need this asap, its for our fire department?? Help Fix
This is Brothers definition of error code 50: "Error Code 50 & 51: The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses."
The manual lists seven different causes, best case being the need to clean part of the mechanism, the worst case being replace the whole main electronics board !
So, no easy fix I'm afraid. You could contact a Brother agent for a repair quote, but in my experience this will cost as much as a new machine. Sorry.
Aug 18, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brothers mfc-440cn - unable to clean 51
The error indicates multiple problems, and needs to be serviced by a ASC Brother Center. Go to and go to support and then service center then enter your zip code or you can ship to us since we are a ASC Center for Brother.
Jan 01, 2010 | Brother MFC-8460N All-In-One Printer
Brother MFC-3360C error message ''PRINT UNABLE 4F .....''
Hi there
Brother 4F is this have a go it could work for you.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Apr 21, 2009 | Brother Multi-Function Center MFC-3360c...
No cartridge
Could you please give some more details:
Do you use gerneric ink instead of the original ones?
When did you get the error code? During normal condition or after a cart change?
This info will quite increase the range of solving suggestions!
Dec 23, 2007 | Brother Multi-Function Center MFC-3360c...
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
453 people viewed this question
James Cagle
James Cagle
Jim Keysor
