Question about Philips 50P8341 50" Rear Projection Television
Hitachi Rear Projection Model 500X18B V4F001550 has converge problem. Colors won't align correctly and colors are weak. Tv is not bright enough. The vertical line has a static line. How can I fix it and locate the area of repair? Also were can I buy the parts?
  • HLFR Mar 05, 2008
    I didn't see anything burn. What color are the supply resistors.
    The board looked good. Thanks,HLF
  • 116 Answers
Most likely bad convergence integrated circuits. STK394-160 is the Hitachi upgrade components. In some cases, the supply resistors may burn as well on the convergence board, but these are easily spotted.
Posted on Mar 05, 2008
  • Paul Buscema Mar 05, 2008
    The supply resistors are small and have various colors. If a close visual inspection does not show any burned resistors, you are probably OK just changing the integrated circuits.
Hi, i have 2003, 57 in" hitachi rear projection tv, model #57G500A. the problem is a thin wavy line across the top and bottom of the screen. could you tell me what would cause that.thank you for your...
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have 2 dead convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Mar 21, 2011 | Hitachi 51F500 51" Rear Projection...
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
There is a gost and crazy color
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D colors look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must have be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Red color is out of alignment
The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require chaging to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
Jan 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
Oct 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Screen is distorted on rear projection hitachi
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 31, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Philips 50P8341 50" Rear Projection Television Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
