Question about KitchenAid KUDR01TJ Dishwasher
Food particles remain on dishes
Lately after a wash there is a coating of food particles remaining on the dishes, cups and bowls. There is also an accumulation of stuck on food particles on the brackets that hold the upper rack. I've tried canceling the drain before each load. switching the type of load (heavy, rinse only etc.) and the water temp is hot enough. Hope you can help!!
  • 1 more comment
  • TroubledD Mar 15, 2008
    I'm havin the same problem on a 13 year old Kitchen-Aid. I've cleaned the spray arms, the food filter, and run empty cycles. But the problem comes back after a few runs. No waste water is remaining after the cycle but it's like waste water wash washed over the dishes right at the end. More debris on upper rack than bottom rack.
  • Vitos Mar 23, 2008
    My KitchenAid dishwasher has never given me a load of clean dishes. I always have food residue stuck to the dishes, the insides of the glasses are always covered and have to be washed by hand after they come out of the machine (highly frustrating and annoying). Have tried every suggestion, none have helped. I hate my KitchenAid dishwasher and will never buy another of their appliances. Oh, and their customer service reps are rude and useless.....when I called because my soap dispenser won't open any more, and she said she would refer a repair company to us....no one ever called. This dishwasher is only 10 months old and cost $1000.00 I am NOT HAPPY!!!
  • bissen Jul 16, 2008
    Exact same issue.  Residue left on dishes, particularly the upper rack.  Have tried to clean.  Now looking into how to take the machine apart to clean filters, or see if water into upper arm is blocked.
  • 3 Answers
This was fixed on my unit by taking out the chopper assembly and cleaning the screen. There is full spray on top now. The screen on the chopper assembly actually had some plastic on it that was hard to see, but was blocking most of the holes. Since this was blocked, the pump couldn't pull enough water to push it to the upper spay arms. My chopper was actually broken so it wasn't clearing the screen, so I had to replace it. That will probably help prevent this from happening again, but if you ask me, the unit was designed poorly for handling normal debris that comes off of plates. I'd recommend inspecting this regularly to keep it clean.
Posted on Sep 27, 2009
Hello I have a dishwasher HOOVER HD 95 M .... I have a problem in my cups and plates remain granules preparation something to do
Check the filtering system and use line filters to eliminate particles that are in your water from entering the washer. Check all of the ports on the spray arm and clean them out. Be aware of the chemicals used to clean dishes as some tend to crystalize when heated and coat dishes. Check that the rinse cycle is working properly and manage your settings accordingly.
Mar 18, 2014 | Dishwashers
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Our dishwasher is only 4 months old. Sometimes there will be small particles of food left on some of the plates. Also when we wash glasses in this machine they are cloudy or dirty looking.
    There are several reasons that the food can be left on the plates. If the washer filter is plugged (partially) then the food particles can remain in the tub and be re-deposited. This can also happen with a dirty sump. According to the specs, your filter is self cleaning, and has a food disposer. The link to your machine is here:
    http://www.sears.com/shc/s/p_10153_12605_02213742000P
    I think, in your case, a good cleaning would help. When the disposer isn't working well, the screen can be coated, and needs to be cleaned to be efficient. Your manual, accessible from the link above, (then select specifications, scroll down to another link) recommends a vinegar wash and is described there.
    For heavy duty cleaning, you can (in this order): Add 1/2 cup of salt, 1 cup of baking soda, and 2 cups of vinegar. Spread the ingredients around the screen, one at a time, at the bottom of the tub. It will begin to foam. When it has quit foaming, add 2 cups of bleach, and run a hot cycle (Pre-heat the water by running the hot water faucet closest to the dishwasher until hot).
    Best regards, --W/D--
    Feb 12, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
    Food particles remain in the dishwasher and on dishes
    Hello, if someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
    If you recently installed a garbage disposal there is a knock out that many people forget to do on the disposal that, if you don't knock out will cause some of the risidual food from the disposal to seep back into the dishwasher...thereby causing particals of food to remain on dishes.
    Thanks
    Jun 17, 2010 | Dishwashers
    After wash, there is still food particle remain i.e. coffee grind
    It is normal for food particles to remain,Just not on the dishes! If there is coffee grains then i dont think it's heating the water.
    May 30, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
    Food particles remaining on dishes after cycle is complete.
    Hi
    While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
    However the other causes for this problem are…
    Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
    Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
    New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
    Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
    If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
    Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
    Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
    Let us know if you want to know something more else please accept the suggestion.
    Thanks for contacting Fixya.com
    Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
    Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
    Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
    Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
    Soap is not disolving. Falls out of holder and stays on door and floor of washer.
    Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
    Most likely causes are:
    Hope this help. Good luck.
    Sep 11, 2009 | Dishwashers
    Film and food residieu remains on upper rack
    Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
    Good luck.
    Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
    Food odor builds up if dishes not washed daily, even though we rinse evrything thoroughly before loading dishwasher. No water remains at bottom - nothing appears to be stuck in drain. Any thoughts?
    No matter how well you rinse wares, some food particles will always go into the machine. Sometimes these particles can build up and lead to what you describe. I would start by inpecting the wash tub area; remove screens, remove wash arms and clean as needed. You are looking for any residual food soil which would harbor bacteria. If all else fails, follow your nose!
    Once everything is as clean as you can make it, then purchase a product for cleaning/deliming your machine. One I know of is called "Dishwasher Magic" which should be available at most appliance repair stores. Run this through the machine on a long or heavy cycle. Once complete, run a second cycle with nothing but water to rinse any lingering chemistry.
    Lastly, for a 3rd (and final) cycle, add a cup of bleach to kill off any remaining odor-causing bacteria. But, DO NOT SKIP THE RINSE CYCLE mentioned above.
    This should take care of the problem,
    Kermit
    Aug 23, 2008 | LG LDF6810 Built-in Dishwasher
    KitchenAid KUDR01TJ Dishwasher Logo
    435 people viewed this question
    Top KitchenAid Dishwashers Experts
    Carmen Mikulic
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
