Question about Panasonic PT-51HX40 51" Rear Projection Television
PT51HX40B so i replaced the STK's with NTE7178, the picture is great when I first turn the set on, but after about 5 mintues it's as if the convergence, (especially red) wants to go bad again. what would you suggest, bad solder joint, other bad components, bad convergence assy? Help and thanks.....
  • 2 more comments
  • tomfix123 Mar 03, 2008
    thanks, i'll give that a shot, i'm very confident i applied enough heat compound. thnx again..
  • tomfix123 Mar 04, 2008
    didn't work, after about 45 mins with fan on chassis the convergence goes all bullocks. what's this with pressing 7 and hold after convergence is set?
    so do i risk pullin traces or pads if i unsolder old ic's?
    i've found the nte7180 in town the 6 amp version should that do?
  • 2,336 Answers
I would suggest to check the solder joints again and also nearby the STKs area, check the low values resistors solder joints as well.
It looks like the ICs are overheating.
Did you apply enough thermal compound before installing the ICs?
Try placing a fan close enough to the ICs, just to see if overheating is an issue.
Good Luck.
Posted on Mar 03, 2008
  • 1 more comment
  • Jaime Hernandez Mar 04, 2008
    Thanks for the feeback and rating.
    If the TV now works for 45 minutes instead of 5, it means that the overheating is an issue.
    You have used the 3 amps ICs, It is safe to use the ones that can handle more current to avoid the overheating.
    Check HERE.
    I would not say you will break traces or pads if you know and how to do it.
    Have you checked the rest of the solder joints in the nearby area?
    Pay attention to the low value resistors as well, since they get hot and that might affect the solder joints as well.
    The 6 amp version should work better than the 3 amp, but you still need to check for dry solder joints before changing the ICs for a higher current.
SONY LED MODEL:40r452a MADE IN MALICIYA
The power supply could be failing
Dec 22, 2017 | Sony Televison & Video
Model:46wt510, turns on, got sound, very dark picture shuts down
five blinks on this unit indicates a weak or out crt tube you can try opening the unit and very gently tapping the bottom of the glass part of the tube to see if you can clear some of the carbon build up from the tube only a temporary fix. be very careful not to break the tube
Jan 25, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi Ultravision 50in. Does not turn on at all
replace Both of your STK ICs STK392-570
Call Mats 1-800-628-1118
Jan 03, 2010 | Hitachi 50UX57B 50" Rear Projection...
Compresor turn off every 3 mintue
ya the compressor might be switch off by the thermostat . the thermostat setting might be not cool or # 2. Or thermostat need replacement if you had set it to the cooler side.
Jun 16, 2009 | LG BG8000ER Air Conditioner
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Samsung p4241w HDTV that will not turn on
Replace Both of Your STK ICs STK392-040s For Parts Call Electronix 1-800-223-3205.
Dec 30, 2008 | Televison & Video
42hp84 toshiba plasma
One of the fuse proballly broken in Board Z- sus due to short cicuit inside the single IC (STK 795-***) hidden under a single heat sink. This big IC was hard to remove.Be gentle when removing the 2 flexiboard.................Tarogo
Sep 14, 2008 | Toshiba 42HP84 42 in. Plasma HDTV
Stk divergent chips
That series usually used the STK 392-110.
It has been upgraded to the STK 392-180. 2 of them.
Mr Bob
www.imageperfection.com
May 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
JVC AV-48WP30 will not give a picture
Replace the convergence IC`s again using original Sanyo chips (STK 392-110 or STK 392-180). Make sure to use plenty of heat sink compound. Coat the entire back side of the chips. Also look to see if any of the low ohm resistors are burned. A shorted chip will cause the thumping sound and the set will shutdown. I am guessing that you used generic IC`s as a replacement. They are cheap and the leggs fall off when you apply too much heat during soldering. Dont wory about the CRT driver or the deflection board, they are probably fine.
Dec 12, 2007 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
