Hey good morning guys
I got a RCA TV. It doe sn't want to turn on. There's like a clicking noise in the back of the tv. Does anybody What the problem is? Please help me.
  • stacyb72 Apr 03, 2009
    clicking in the back of the TV. Gets louder and louder when the TV is on...and can see the screen kinda flicker when it clicks.
    Scholar:
  • 133 Answers
Depending on the model # most of the time it is a bad flyback transformer . If it also has the high pitch squeal the horizontal transistor is bad as well . Just a clicking noise bad flyback. Some of the originals are not available and a generic is the only replacement. A repair shop may charge between $80 to $135 to repair so shop around . Ask them if there going to use a generic as they are cheap $20 to $30 . Good luck
Posted on Mar 03, 2008
I turned my 52 inch RCA floor model tv on this morning. I heard a sizzling noise and now the picture is different colors
Hi if this is a rear projection TV, picture control module faulty or possible PC board damage. requires technical repair .
Jan 01, 2015 | RCA Televison & Video
My rca opal m4204 wont turn on
We bought a while back a surround sound system with a SONY Dolby Digital FM Stero FM/AM Receiver STR SE501, a small subwoofer and small centerband spearker. We recently upgraded to two better and larger submwoofer and centerband speark: ICON VC25 CENTER SPEAKER (SN 100987108520533 SW-350 SUBWOOFER (SN 101043809321322 Problem we are having is, when we turn the TV on in the morning, about 10 minutes, we hear a click noise in the receiver, a pop loise in the subwoofer, and the it cuts of the speark. It with click again, cuting the spearker back on, then do it agian and cut them off. It seems once it does this a few times, and comes back on, it stays on the remainder of the day. What is the problem? Do we need to make an adjustment to the receiver, because of the upgrade. We original had moster cables. Do we need to replace them? Hope you can help. Tony (arod13tb@yahoo.com)
Jan 09, 2010 | RCA Audio Players & Recorders
Samsung LNT4061FX makes clicking noise before coming on.
Replace capacitors in power supply you will see that they are bulged on top
Sep 13, 2009 | Televison & Video
My Samsung txn3245fpnxxaa television only clicks when powered.
seem like a power supply problem.
to my experience this kind of problem worth the fix.
Depend if you have a good repair guy, ;)
Jun 20, 2009 | Samsung TXN3245FP 32" TV
RCA TruFlat 32" Blue light flickers, clicking noises, help!
OK for the start, try this unplugged your unit for about 60 sec. Then plugged it again and switch on. Does it help?
If not then dont connect your surge protector in line for the meantime. Power the unit. This is to isolate whether your surge protector is defective or not. Does it help?
If not, this could down to your high voltage section, if this is a crt tube tv. You might loose your flyback transformer, and or the horizontal output transistor. Checking its peripheral component is a must. That clicking noise is the relay, thus this have relay?
If your not into electronic, have it service.
Apr 28, 2009 | RCA TruFlat 27F520T 27" TV
LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Feb 25, 2008 | LG 37LC7D 37 in. LCD HDTV
Constant clicking every half-second as soon as you plug it in.
I have the same problem-still troubleshooting...so far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Aug 29, 2007 | RCA F38310 38" TV
TV went out
Hey Jim, The high voltage protection circuit has gone out on the D-board and will need to be replaced. The fuse to the power supply is probably fine. A good repair tech shouldn't charge over $125 for this and it only takes a couple of hours. Let me know if I can be of further assistance.
Jul 17, 2007 | RCA F27242GY 27" TV
Clicking noise+horizontal flashes
What you are hearing is the high voltage arcing a bit. This is often caused by dust buildup on the high voltage components, & is not harmful. A good cleaning with compressed air will cure it, but this is not a do it yourself job, because dangerous voltages are present inside any TV.
Jul 13, 2007 | RCA F36450 36" TV
RCA F32649
Sounds like you have a shorted horizontal out put transistor and bad flyback transformer. This is a common problem in the newer RCA's. I've had serveral of them do this. The noise that you hear is the power supply telling you that it's overloaded. Stargazer
Feb 17, 2007 | RCA F32649 32" TV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
