Question about Motorola Mobility RAZR V3
Where do you put the Micro SD card in a Motorola V3 Phone.
Someone told me I could use a micro SD card with a motorola razr V3 phone, and that you put it in the phone somewhere by the battery, but there there is no slot for it anywhere on the phone........Is it possible to use them with the phone or can you not? Im really confused about it -.-'
i Can not find the slot to put a scan-disk micro SD card where dose it go?
  • Anonymous Jun 07, 2008
    i dont dnow where to put my micro sd card in my RAZR V3
  • mustafa_linc Jun 18, 2008
    how can I use a micro SD card with LG970
    phone, where shall i put it in the phone. There is no slot for it anywhere on the phone!
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
Posted on Mar 04, 2008
  • Techpilot64 Mar 04, 2008
    The Motorola Razr V3xx also has a micro-sd slot
Well... the motorola razr v3xx has a slot just underneath the battry but also god loves jesus so it evens out.
Posted on Oct 10, 2008
Its true! my razr does not have a slot for a memorly card. i dont know why.
Posted on Jun 08, 2008
Check under the battery compartment there's a tiny slot that can be inserted there but u need to remove the battery so you can see where it goes.
Posted on Sep 15, 2008
How do i put a micro sd card in my at&t razr?
To install this, turn off the phone. Remove battery cover. Remove the battery and install the memory card into the slot. Make sure it is fitted correctly.
Jan 09, 2010 | Motorola Mobility RAZR V3
MMy motorola razr phone deosn't recognize 4 gb PNY
The 4gb card may be larger than the maximum card size that the phone can read. The maximum may be 1 or 2gb. If its over the maximum size supported the phone wont be able to recognise it
Sep 22, 2009 | Motorola Mobility RAZR V3
I unlocked my motorola V3 razr and i cant get pictures or get on the internet
Are u trying to download to phone or a memory card? If you have micro SD card use program to send to mmc then pictures.
Jun 12, 2009 | Motorola Mobility RAZR V3
What do I have to down to get picture off my phone
Are the pics saved to phone or in the camera?
If saved to phone.Do you still have service for the internet on the phone?
If you do you can send the pics to an email address.
If in camera you need a 2 gb or lower micro sd card, micro sd card reader, and a sd card reader.
Oct 14, 2008 | Motorola Mobility RAZR V3
Polaroid micro sd card stuck in motorola razr v3
these a little dificult sometimes but they just need a little julting to get out. just use a pointed knife or a small screw driver and just push it backwards firmly and that should do it.
sam!
May 05, 2008 | Motorola Mobility RAZR V3
Limited memory
I am sorry but there is no way to add more memory or a memory card slot to the Motorola V3.
Apr 01, 2008 | Motorola Mobility RAZR V3
Memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
I know of a solution, but it is dangerous to your phone and it will probably void your warranty ifyou break it.
1) open the back of your razr, revealing the battery and the sim card.
2) do you see the small screws that hold the lower part of the phone on? there located on the edge of the phone.
3) unscrew these and take off the black casing that both holds your SIM card in place, and prevents you from putting in an SC card to your phones motherboard.
4) place the sd card onto the pannel of your motherboard, making sure that it fits properly.
5) put everything back together and your done, you now have a thrid storage device on your phone.
Feb 26, 2008 | Motorola Mobility RAZR V3
Cant find where to put the micro sd card on my motorola v3
take the back off the phone that covers the battery.....on the left side next to where the sim is inserted you will see a silver clip place the MicroSD card in the slot....:)
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
3,483 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
