Question about JVC MX-KA3 CD Shelf System
System automatically shuts itself off after a few seconds.
I'm trying to help a friend of mine who has a JVC MX-KA3 stereo problem.
Upon plugging the system in, it enters standby mode just fine. The display cycles through various messages.
However, once any button is pressed and you try to get the unit to perform any function, it automatically shuts back down. It will display the "Good Bye" message and shut down.
I'm no expert, but I'm pretty handy with a soldering iron, etc so I am hoping someone here might be able to point me in the right direction to troubleshoot.
Thanks!
Ryan
    Problem Solver:
  • 13 Answers
I have no Idea, I have My JVC system sitting in a closet. I got it in 2004, and It was working fine, and all of a sudden it stopped and went into protect mode. I have no idea what to do about it.
But this is what I did.
I unplugged it and I let it sit for 24 hours to see if it would Reset the microprocessor, that did nuttin'. So I took it apart ^_^ That was fun! and I checked all the wires for loose connections, and I made sure te cables were in there tight. My unit is a pretty old though, I have a surround sound system, but usually a good blast of canned air may clean the circuit board and the components.
Cheers!
Posted on Mar 23, 2008
How do i get the cd component to open
The CD open/close button is the far right button of four beside the center control. It's marked with an up arrow. http://resources.jvc.com/Resources/00/00/33/76.JPG
Jun 22, 2014 | JVC MX-KA3 CD Shelf System
My JVC CA-MXKA3 it say protected when i switch it on, i have also try to switch it on weout speakers but it still say the same thing. Please help me on what to do
http://www.retrevo.com/search?q=JVC+MX-KA3
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 18, 2011 | JVC MX-KA3 CD Shelf System
Protect on display and nothing works
probably your stk output ic is faulty.....................................nacho
Jan 07, 2011 | JVC MX-KA3 CD Shelf System
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Dec 12, 2009 | JVC MX-GC5 CD Shelf System
Protected
You got to open this puppy up and replace the 2 bad IC boards.  Known problem with this brand stereo.  Defect in the IC boards causes your fuses to blow and they will keep blowing every time you try to put new ones in.  Cost for parts will be about $200.
Aug 15, 2009 | JVC MX-GT88 CD Shelf System
Screen says 'LOCKED'
Hi tammiedahmer ..to this problems have a sulution in the page 15.. of the INSTRUCTIONS..
I hope I have helped you .. even more ..
Nov 15, 2008 | JVC MX-KA3 CD Shelf System
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
MX-KA3 SAYS PROTECT
I need a little help on this one. Did it go into protect after the move or was it in protect mode before? If it went into protect after the move, did it get dropped or roughly handled? Sounds like something got knocked loose in the move. You should be able to open the unit up and check the connections. Reseat all connection whether they look loose or not. Sometimes it only takes a very small bump to get the connector acting up. After reseating all connectors, if it still does not work let us know.
Feb 09, 2008 | JVC MX-KA3 CD Shelf System
Trouble keeping it on
hmmm....try unpluging it plugging it back in then turning it on then run along the wire there maybe a splice in your wire causing it to shut off
Oct 17, 2007 | JVC MX-GB6 CD Shelf System
JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Jan 24, 2006 | JVC MX-KB30 CD Shelf System
JVC MX-KA3 CD Shelf System Logo
286 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
