Question about Brother ML-500 Typewriter
Typewriter Brother EM-530
How do I set the margins on this typewriter?
    New Friend:
  • 120 Answers
You have to position the carrier to where you want the margin using the space bar or backspace key. Once you get to the desired position you must press either the left or right margin button depending on which one you want to set. You may have to use the code button together with the margin button. Lawrence
Posted on Mar 04, 2008
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
I can't get the right tab set far over to the right!
First check that your right margin is not set before the tab. Your margin could be stopping you before the desired tab position. Hope this helps.
Oct 12, 2013 | Brother EM-530 Typewriter
How do I clear the right margin?
Usually, with most of these machines, you move the print unit to the margin and then press Margin Release. This will allow you to move the print unit along to where you want to set the margin.Then you press the Set Margin key.
Apr 20, 2010 | Brother EM-530 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
How to use the margin release for Brother EM-530
Is Margin Release on it's own separate button on the EM-530? If so, then to move beyond a margin:
  • Use Return or Tab to go to the left or right existing margin.
  • Touch Margin Release.
  • Use the Backspace or Space bar to go beyond the margin in question.
  • If you want to set a new margin, then go to the location you want to have it and touch the Left margin or Right Margin button.
Some models may require the CODE key to access one or more of these functions. If the function name is not printed on the top of the key, but on its front or on the surrounding plastic above the button, press and hold the CODE key while touching that button (just as you hold the Shift key to type capitals). The CODE key might possibly have a different name; chances are it's color will match the functions it works with.
Jan 05, 2010 | Brother EM-530 Typewriter
Can't change the right margin
You must first position the carrier to where you would like the margin to be set, so if you want the margin to the right of where it already exists you must to the the margin and Depless the margin release function (M rel). If the typewriter is in line-by-line mode you may have to select the TYPE mode , before you do this. When the carrier is position to the place you want depress the R margin set function (CODE plus M left)
Nov 25, 2009 | Brother EM-530 Typewriter
Margins
Hello I can help.
Here is a free User Guide for your Brother EM-530 Typewriter
if you need anything else, please feel free to call or email us.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
8-5PM (pst)
MON-FRI
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CM1000_EM530_EN_226.PDF
Sep 10, 2009 | Brother EM-530 Typewriter
I need manual for brother EM-530 typewriter
Go to http://www.brother-usa.com/typewriters/. Click on "Manuals." Select "Typewriters", then select your model number in the drop down boxes. Click on "View download." Click on the "Users Manual - English" and the manual will open in Adobe as a PDF file. Print it or save it to your computer for future use.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 17, 2009 | Brother EM-530 Typewriter
Margin Resetting
position the carrier where you want the margin and press the left or right margin key. Lawrence
Feb 08, 2008 | Brother EM-530 Typewriter
Brother ML-500 Typewriter Logo
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
