Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Printer does not power up
Printer has 3 flahsing lights...scan/copy/fax but does not seem to self test
    Sergeant:
  • 406 Answers
None of the leds are flashing or indicating the power.
First Possible solution is change power cable or put the one which is already working Cable. If Its not getting power Check the fuse of Printer. If nothing Works Consult to service center as it seems to be under Warranty before doing any manipulation in the circuit.
Regards
Rafique
Posted on Mar 03, 2008
HP 7210 Officejt is not printing
Are you able to make copy from printer or print test page ?
If you are not able to make copy from printer or print self test page
Check if the cartridges are not empty.
If they have ink, follow the steps below
1. Disconnect the power cable from back of printer
2. While holding the # and 6 button, connect the power cord to printer.
3. It will print the alignment sheet and you will have to re-align the printer and try to print/copy
*Note this is Semifull reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Or are you not able to print from PC ?
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP Officejet 7210 All-In-One InkJet...
My HP officejet 6210 all-in-one just stopped working. When I try to fax, copy, or scan, the process starts (i.e. menu acknowledges, hear clicking, etc) but then stalls. The green (on/off) light blinks and...
You can try Full Reset on printer
Disconnect power cord from back of printer ( while printer is on )
While holding the # and 6 button connect the cord back and release the # and 6 after 3-5 seconds..
The printer will turn off and will turn on again.. follow the Alignment process
Note : By doing this Full Reset - you may loose any Speed Dial/Group Dial entry from the printer
Also try changing the Printer Socket, Connect to walljack directly or another socket on the Surge strip.
Jun 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My Dell A810 won't scan. Prints ok, copies ok but won't scan. Have Vista home Premium and a new Dell Inspiron. have uninstalled and reinstalled the printer twice but still won't scan.
Can't remember, but I believe you should have a fault programme which can access to run a self check?
All in one means able to send a "Fax".
If I'm right you have two settings for faxing, either entering doc in to tray or placing on scanner to be copied then faxed.
If so and you are able to fax to anoth er fax number see if you can send fax via your scanner. I'm am trying to find out if your scanner then starts up, strode lights up and copies, least you know important bits are working.
If it does light up, chances are present prog is not vista compat. Go to www.hp.com enter your printer details search it will come up with latest updates and full progs, look for the vista prog. Good Luck.
Nov 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My X8350 stopped working this week. I have power
HI,
Please follow the instructions given below to know exactly when the light is blinking:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the
power from the printer. Open the front cover and move the cartridge carrier to the center.
You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the
cartridge carrier that you will not be able to see. Reach in with the first finger of
either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be
careful not to break the strip or your printer will not function. Once you believe the
strip is set correctly, plug the power back and let us know if the lights are still
blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting,
if the strip breaks, you will not be able to use the printer. We will replace the printer,
only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check
if you can see any lights blinking. If light blinks with one cartridge then that cartridge
is defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail,
please let me know.
your's tech expert
Jeeth
Sep 25, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a lexmark all in one and was trying to make a copy
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the purple/silver button is pressed?
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Make sure the printer is off.
2. Press and hold the "Color Copy" button.
3. While holding the "Color Copy" button, press and release the "Power" button to turn the power on.
4. Wait for the "Power" light to flash off and on.
5. Release "Color Copy" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
May 14, 2009 | Lexmark X2500 All-In-One Printer
LEXMARK 7350 IS NOT WORKING
HI,
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
Dec 28, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark Printer
If the scanner is clicking than it is a scanner issue. Make sure there is not a lock button on the machine. They sometimes have these for when the printer is being moved. As for the faxing software it would seem that that part didn't not get installed so if you can update it.
Apr 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
