Question about Panasonic NN-T994SF Microwave Oven
Microwave no power to unit, there is power from receptacle
  • 2,130 Answers
Mst likely a blown fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 03, 2008
Had a small fire in the microwave and the power went out. Power is on to the receptacle, but there is no power in the unit. Is there a circuit breaker in the unit or is it toast?
Jim, a lot of microwaves have internal fuse, question is do you really want to bother after it has been on fire. Just a thought.
Good Luck.
May 04, 2016 | GE Hotpoint Over-the-Range Microwave
How do I check for power inside the unit.
does it light up when u open door?
Oct 06, 2015 | Microwave Ovens
Whirlpool microwave gh7208xrb-3 fuse is good but the unit has no powernothing lights up at all it like it is dead.
Control board might be dead. Cost is quite high could run up to $200 or more. Many times I recommend just to replace it. Here's the dumb question, is power present at receptacle?, if over range microwave, in cabinet above microwave? Check for gfci receptacle tripped. Sometimes fuses appear good, always be sure to test with a meter.
Oct 28, 2013 | Microwave Ovens
Microwave Fried
Unless a expensive unit I would replace it as the main power supply for the unit a who knows what else got toasted---
Aug 27, 2012 | Microwave Ovens
No power to Samsung SMH 9151
The main fuse in the microwave oven has probably blown.
Mar 28, 2012 | Samsung SMH9151 Microwave Oven
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
No power to clock or microwave. Have checked breakers.
The main fuse in the microwave oven has probably blown, caused by a defective door.
Feb 07, 2011 | Jenn-Air JMC7000 Microwave Oven
GE Microwave Model JES1651SJ-02, Serial 902410. Unit appeared to be fine yesterday evening with the clock working properly but this morning it shows no lights and keypad is not operational. Checked both...
There will be a fuse, magnetron thermostat / thermal cutout, and an oven cavity thermostat / thermal cutout.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 08, 2010 | GE Microwave Ovens
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Microwave shut off like it lost power but the receptacle does have power to it. My model is an LVM1750.
The thermal cut out switch in the cavity is bad. I was unable to locate a wiring diagram on the internet but when I took the microwave apart, I found the wiring diagram inside the microwave on the back side of the touch panel.
This unit is mounted above the stove. We were cooking on the stove and also in the microwave. I think there was enough heat to trip the TCO switch.
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-T994SF Microwave Oven Logo
116 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
