Kenmore Washer 70 Series shakes badly during spin after repairs
My husband and I just replaced the clutch on our 70 series Kenmore washing machine yesterday after doing some research here and elsewhere on the web. Everything went okay until after we reassembled the machine. When it gets to the spin cycle after rinse, it starts out fine and then shakes very badly, almost like something is not hooked up. What have we missed? Any ideas? My husband said that there was a small plastic clip that broke when he was taking it apart.
Thanks for any help
  • 2 more comments
  • HandyMaam Mar 04, 2008
    We took the washer apart again last night and noticed that the triangle piece that you mention (some kind of support plate) was loose. We looked on the sears website and located it. After much adjusting it looks to be in the correct position. We did notice a pin that had fallen out and thought that maybe in was to secure the plate. We placed it in and secured it with a cotter pin. It seems to work better but with some rattling because of the pin. You are correct in your information thank you. Do you know anything about this pin though
  • HandyMaam Mar 05, 2008
    Sorry, It's me again. Evidently it isn't fixed properly as it is doing it again. Can someone tell me how to afix the plate properly? Thanks for all of your help.
  • YG13 May 28, 2008
    Hello
    I fixed the coupler but now have the same problem the other person did where the tumbler shakes like crazy in the Spin cycle. It starts off fine but at the highest speed, it vibrates making a loud noise.
    I did put the washer on its front laid down with the back plate facing up when I removed the transmission assembly bolts. When I read more about the coupler, I put the bolts back and fixed the coupler. Now I notice that the unit works. But the shake is bad.
    Thank you
  • Anonymous Mar 19, 2014
    Shakes during spin cycle
  • 156 Answers
Make sure that the 3 corner triangel thats betwwn the tub support and the base is in the right position all 3 parts corners should be pointing the same way
Posted on Mar 04, 2008
  • craig carter Mar 05, 2008
    yes make sure you remove the pin its is a shiping pin take the pins out and you will be troubel free have a good day
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore 70 series washer only spins sometimes
if it only spins with a light load or non at all then you have a bad clutch assembly and it will need to be replaced
Apr 20, 2012 | Kenmore Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 70 series is slow to spin
it sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
517 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
