I reloaded my printer software on my computer and as it were loading a screen came up tha say (runtime error)My printer is about a month old it is a(all in one lexmark 5000 series X5070)
    Sergeant:
  • 406 Answers
Please unistall all existing drivers for your Lexmark printer driver. remove all the programs unnecessary from windows tra right side down the screen . And Install it again.
Posted on Mar 03, 2008
There is a system error at runtime Cide: 101-8193
if it is tonner replace it, if it is ink cartridges replace it, think it may help god bless
Oct 01, 2011 | Kodak 5500 ALL-IN-ONE PRINTER
No Software from disk will not load using Vista
hi, i guess your os is definitely corrupt. in such case i advice you do a clean forma of the os. just back up your files and then format it with the os installation cd
Jan 23, 2010 | Computers & Internet
Runtime error !
u need to repair the operating system install or reload the computer by formatting it and load it back
Jan 17, 2010 | Computers & Internet
Runtime error
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now. NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
Mar 31, 2009 | Microsoft Picture It! 2002 for PC
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Keeps saying theres a runtime error
What type printer? 2.) what operating system? Is the error on computer screen or the printer? Have you tried upgrading the printer software? Any operating system upgrade changes etc windows service pack 2, or 3 let me know
Nov 26, 2008 | Lexmark Office Equipment & Supplies
New Printer Installation Error
ISSUE: When trying to install an HP LaserJet P2015 printer, a MSVCR80.dll error message is received.
SOLUTION: To resolve the issue, complete the following steps:
  1. Before installing the printer, disable any Anti-Virus and/or Firewall software. To disable the Anti-Virus and Firewall software in Microsoft Windows XP and Microsoft Windows 2000, press the Ctrl+Alt+Delete simultaneously to enter the Windows security screen. Then select Task Manager , select the Process tab, select Anti Virus and/or the Firewall Image , and end process on the software.
  2. Disable XP firewall. To disable the firewall in Microsoft Windows XP, right-click My Network Places , select Properties , right-click Local Area Connections , and then select Properties . Select the Advanced tab and remove the checkmark from Internet Connection Firewall .
  3. If the issue persists, before trying to install the printer, we suggest you complete follow the steps:
    1. For system clean boot to perform, click Start , click Run , type msconfig in the Open box, and then click OK .
    2. On the General tab, click Selective Startup , and then clear the Process System.ini File and Process WIn.ini File , and Load Startup Items checkboxes. You cannot clear the Load system Services and Use Original Boot.ini checkboxes.
    3. On the Services tab, select the Hide All Microsoft Services checkbox, and then click Disable All .
    4. 4. Click OK , and then click Restart to restart your computer.
    5. 5. When the system restarts, click Start , and Printers and Faxes . Delete all the printer icons.
    6. 6. Click Start , click Printers and Faxes , click File , click Server Properties , and then click the Drivers tab.
    7. 7. Select all the printer drivers individually, and click Remove . Remove all the drivers one by one.
    8. Click the Ports tab and delete the listed TCP/IP ports individually by selecting the Port and clicking Delete Port .
    9. Click OK , and then restart your computer.
    10. When the system restarts, begin the installation process. You may insert the installation CD into the CD-ROM and follow the onscreen installation steps to install the printer locally.
      NOTE: Do not connect the printer to the computer until prompted to do so during installation.
Oct 28, 2008 | HP LaserJet P2015dn Printer
Xerox Workcentre 24. 20 months old. The sreen simply says: Fault/Error, then below: A fault has occured. Switch the machine Off and then On. If the problem persists, call for service. In the bottom left...
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Oct 02, 2008 | Xerox Office Equipment & Supplies
Im getting 2 msg 1st error found code 0x80072ee2 & the 2nd microsoft visual C runtime library runtime error program:C:\windows\SMINST\BLservice.exe.just brought com only had about a week
are you installing a printer with old software drivers, as they may not be compatible with Vista, check the printer website for updates and patches.
Aug 31, 2008 | HP Computers & Internet
Computer Crashed
Please follow this link, choose your operating system and then download the link for the software on that page:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Z715
Thanks,
Lolita
Apr 08, 2008 | Lexmark Z715 InkJet Printer
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
