Question about Electrolux Central Vacuum
Central vacuum Hello, my central vacuum motor just clicks when you insert the hose into the receptacle. Is there anything I can do besides get a new motor or unit?
  • 20 Answers
If the central vacuum is clicking that means that the circuit breaker is working and trying to get the motor to run but the motor is not functioning. This means it's time for either a new motor or a new unit. Unfortunately there's really no way around that. You might want to replace the entire system though because you have to think about where your money is best spent, putting a bandaid on your old machine or investing in a new machine that will last you up to 20 years.
Posted on Feb 22, 2012
    President:
  • 1,673 Answers
Check the motor brushes, they may be worn down and not making contact with the armature. There may also be relays and one could be bad.
Posted on Mar 04, 2008
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Easy Flo Central vacuum will still work at about
Yes you can easily test for a clog, and a crack for that matter.
to test for a clog push a dry garden hose through the entire system until it comes out at the other end.
to test for a crack, Disconnect the pipe that comes from the house to the central vac unit. Turn on the unit and put your hand over the opening directly at the central vac unit.(Using the utility inlet at the unit will not accomplish the same thing.)
  • Step 2 If your suction is good, then reconnect the tubing and turn on the switch at the unit. If there is no switch, plug your central vacuum hose into one of your inlets to start the system. Then have someone completely seal the hose with their hand. While the unit is running go to the exhaust. With everything closed you should feel almost nothing coming from the exhaust. If you feel very little exhaust, then you do not have a leak
  • Jun 06, 2009 | Easy Flo EF2300 Central System Vacuum
    Vacuum won't turn off
    This is a common problem i see it weekly. You just need to replace the relay in the tank. have an electrician or vacuum tech do it so its done correctly without causing more problems.
    May 26, 2009 | Broan-NuTone CV350 Central Vacuum
    Pushing in the hose to the inlet receptacle on the wall does not initiate vacuum suction
    check the electrical contacts around the tip of the hose.Check another wall inlet around the house and see if it starts.If it does starts in another inlet than there is a problem with the wiring at the inlet where is not starting.If the vacuum does not start in any inlet check the power button at the vacuum location and the fuse.Also I should mention that if your brush have an on and off button you should check that is on.
    Apr 26, 2009 | Vacuums
    Problems with 353 nutone
    if its an older unit or it got heavy use it could be the motor they tend to sputter as there going out, as it rotates the electricity hits a burnt spot inside the motor and shuts itself off can you turn it on manually? they usually put a swithc on the tank itself if the problem doesnt occur when you switch it then it could be the hose itself normally they control the off/on use a meter to check the continuity beteen the two copper plates that are on the end of the hose ( the wall end )
    Sep 16, 2008 | Broan-NuTone VX475 Bagged Central System...
    Electrolux central vacuum
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=491377
    Posted by judiths on Apr 05, 2008
    Help! It works fine until I plug in a hose and then the unit surges--kind of like its breathing.
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a weak motor and when it takes on a load it starts to over load and or surge – but if the motor is still under a factory warranty then contact the vendor who installed it because if you work on a unit that is under a factory warranty then it will void the warrant. It is not the vacuum inlet because that only uses a low volt wire. So if it beyond the factory warranty then contact your local vacuum cleaner dealer in your area or cal the Electrolux factory for further information and or an owner manual on the unit giving them a model # and serial # so they can download the correct service manual for you. Your motor may be in need of service but be careful that the repair and labor does not exceed the cost of a new motor.
    So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://electrolux.com/ Customer Service 1-800-896-9756
    Electrolux Home Care Products – North America
    P.O. Box 3900 Peoria, IL 61612
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Apr 05, 2008 | Electrolux Central Vacuum
    Central vacuum not sucking
    Usually when there is no suction, and the main unit is running, then either the hose or somewhere in the piping there is a clog. If you move the hose to another location, is there suction? If not then the hose is clogged. You can unhook the pipe at the unit, flip the switch to manual, if it comes on and there is suction there, then there is a clog in the piping, If in the piping, tear up small strips of paper and mark them by number and insert one in each inlet, run the unit on manual to suck them up, and which ever numbered strip isn't there in the bucket, then that is the inlet that is clogged.
    Nov 23, 2007 | M&S Systems AirVac AVP1200 Platinum Series...
    Vacuums Logo
    138 people viewed this question
    Top Electrolux Vacuums Experts
    Mack Baxter
    Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
