Question about Motorola Mobility H500 Wireless Headset
No sound comes from my headset
My earpiece worked fine last week. But yesterday. when i tried using the speaker only comes from the phone. Its is properly paired and connected. i can push the button on the headset and it will call the last person i talked to just fine, but the sound is not coming through my eairpiece only the phone.
  • Anonymous Mar 04, 2008
    yep got same problem plz help
  • rendie2000 Mar 05, 2008
    I figured out that the problem was that i needed to fully charge my earpiece. charge it till the light goes off . Mine works fine now!
Hey, i had same problem and i found just turning my phone off and on to solve the problem
hope this helps
Posted on Mar 04, 2008
Had same problem i found just turning my phone on and off to solve the problem
hope it helps
The speaker in my MOTO ROKR E6 stopped working since today morning. It was working till yesterday. The only thing that I did was I added a new SIM card for the phone. The video and Audio was actually...
This can be a coincidence but I feel that the earpiece speaker is faulty. Since your headset is working then it is for sure that the circuit is functioning. So it is either a connection of the speaker jack not linking back to the speaker after the jack is withdrawn. SO if you are able to open the phone check with a multimeter on the earpiece speaker. replace if faulty.
Feb 04, 2011 | Motorola Mobility ROKR E6 Smartphone
I have a new phone model lg km555, but unfortunately after 3 weeks i wasn't able to hear any sounds from it. its like in a silent mode. but i tried it with headset, it works. what can i do?
The earpiece is not functioning or the speaker is not working accordingly. Remove the panel to check the earpiece if faulty replace, if not check the connector, the connections to the earpiece jack section as since the headdphones are working there can be a break inthis section. Use a lens to check carefully.
Sep 14, 2010 | Cell Phones
Cannot hear anything on receiving call bt able to hear with speaker on or on hand set......
you have to change your speaker (earpiece)
when you choose the loud speaker option,,
you will able to hear the voice,,why?because the sounds transfer from earpiece to buzzer..its same when you use headset..the sound from earpiece will transfer to headset speakers..in that case,,you need to replace your earpiece..100% your problem will be solve!!
Jun 16, 2010 | Nokia 3110 Cellular Phone
The normal earpiece (not headset) has no sound. I have to either use headset or use speakerphone to hear whoever I'm talking to... just started yesterday..all of a sudden, no slw fade or anything. worked...
Normally Motos blow the top end speaker! Most of the time they are soldered, but I haven't done a phone of this model for a while , so cannot remember . If possible , try to get a V3 speaker from somewhere and then disassemble phone, to see if it will work. V3 spkrs are much cheaper , and usually work on many motos . If the speaker is round , it may need to clean the elastomer, so if this is the case email me at fonegeeks@ hotmail , and I will attempt to talk you through it . Need to open handset first :] cheers!
Sep 04, 2009 | Motorola Mobility i850 Cellular Phone
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Good luck from Headsets Direct!
Feb 14, 2009 | Plantronics Explorer 330 Headset
Bluetooth not working
Make sure you have connected the bluetooth correctly, if you have and it still doesent work, your phones bluetooth capabilitys my be Gliching or broken. Also make sure you turn the volume All the way up.
Dec 24, 2008 | Motorola Mobility HS850 Consumer Headset
No sound coming out of my laptop it's been working perfectly for almost a year until last week when I unplugg me headset and the sound is not coming out!built in speakers but if I plug in my headset it...
you could try to use system restore, to restore it back to an operational point before last week.
reboot with the headphones in, then take them out, then restart again.
Nov 12, 2008 | HP Computers & Internet
LG Rumor Internal Earpiece Toggles from Working to Not
There could be a short in the earpiece. This can be fixed at a repair center if they are stocked with the right parts. If not they can still check out the phone and see if it is eligible for an exchange.
Nov 05, 2008 | LG RUMOR Cellular Phone
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
No Sound on the phone
It is probably cause by some dirt in the o2 port that causing the switch that detect the headphone to stuck. try cleaning/picking them up using a small toothpick or needle.
Dec 17, 2007 | O2 Xda Atom Exec Smartphone
Motorola Mobility H500 Wireless Headset Logo
120 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
