Question about HP OfficeJet Pro L7580 Color All-in-One Printer
Getting error when trying to fax or scan
I just installed a HP Officejet Pro L7580 and am getting a "An error occurred While communicating with scanning device' message. The printer is connected via network cable, no USB attached to it.
I am running Windows XP Media Center edition SP2 on a
Dell XPS 600
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Posted on Mar 09, 2008
I keep getting error message 388 whenever I fax to any number. I have been able to receive faxes. My all in one is an HP officejet pro L7580
You probably need to run the fax test to check if the fax mechanism is working fine.
Click on Setup Button ( ranch like symbol ) on the printer front panel.
Scroll down till you find Tools ( press ok )
Check for Run Fax Test ( Press OK )
It will print the test results and everything should pass.
To solve your fax issue, follow the steps below.
Check for Advanced Fax Setup ( or Basic Fax Setup ) - Press OK
Look for ECM ( Error correction mode ) - Press OK
Turn the ECM OFF
Try to send fax. It Should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
When I try to fax a document to another fax Machine ( either via feeder or through software), I am always getting an error message " A communication error occured..." (Error 387)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Dec 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Pxma mx860 getting cooo error message
how can i connect my printer((HP Officejet Pro L7580 All-in-One)Printer , Fax , Copy)) to my hp Laptop Computer .
Jan 14, 2010 | Canon Office Equipment & Supplies
Scanner function will not work.error message--"no scan options". have reinstalled software plus downloaded software from hp website.
Cobbled together a MS scan option that works with the L7580. Not very seamless but I'm scanning, viewing, saving and emailing OK.
Still wish I could get the darn L7580 to work via the "scan" button!
John Boggess
Jan 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have the scan button but it will not allow me to
Hi, The reason you're getting this is because you need to have compatible software installed on your computer. The disk that your printer came with will come with the relevant software but you might want to check the HP website for something more up to date as they have released fixes over time. Once you have that installed I would use the proper software to request the scan from the printer rather than trying to use the scan button on the printer itself. To be honest I have no idea why HP put that button on there as it makes things more complicated than they need to be. Oh, also worth noting that any software that can work with TWAIN compliant scanners should be able to see and use your L7580 without anything new so it may be worth checking anything already installed on your computer to see if it already does what you want. Hope that helps. Martin
Jun 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
2007 won't scan to Word using HP Officejet Pro L7580
unfortunately the following is from MS Word 2007 Help:
The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
Sorry.
Sep 26, 2008 | Microsoft Office Professional 2007 Full...
scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
  1. Open the HP Director/Solution Center software.
  2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
  3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
  4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
    Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
Causes:
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
regards,
coffeebeans
Mar 15, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
226 people viewed this question
Ben Johnson
