Sony home theatre system
My sony reciver is flashing ;protect' after have an extension cord short out. i have unhooked all speakers and unplugged the reciever,still in protect mode. my husband and i were painting and we have a tv installed on the wall, when i moved the system back, a cord shorted out! have i fried the reciever? have done everything i have read and nothing is working! the model # is-sony str-k900. thanks in advanc for any help
  • 1 more comment
  • dixie lady Mar 04, 2008
    thanks, i am going to do that today, rewire speakers etc. will let you know if that works.
    thANKS FOR THE ADVICE, I DID CHECK ALL SPEAKERS AND THEY ARE SECURELY WIRED. STILL IN 'PROTECT' MODE' I WILL CALL AUTO TECH AND RELAY THE INFO YOU GAVE ME TO HIM.
  • dixie lady Mar 06, 2008
    hi again, i called rex and they said i could buy a new protecter fuse at radio shack, took the top off the reciever and i need to know if you guys can tell me where and what the fuse looks like? i see a tiny fuse looking thing , but am afraid to mess with it without knowing if that is it. am having trouble finding a dealer in this area[small town}. the guy that installed it hasn,t returned my call!!. thanks i advance for any help;}
    President:
  • 1,944 Answers
Good enws is yout unit is not fried. Bad news is you need to get the protection fuse replaced...
Posted on Mar 04, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Mar 04, 2008
    Did you check that all other cords/cables are in good condition?
  • Damen Wong
    Thanks for the update. It is very probable that the protector fuse just needs to be replaced. Good thing that it's there too...saved your whole system.
  • Damen Wong
    Let me know how it goes.
On my lg 4030 home theatre system,s-protection message pops up and the system turns off
Unhook the speakers and turn it on, if it stays on then one speaker is shorted, if it does not then unplug all the inputs and try again.
If it does not work then it needs to be serviced for a bad overload detection circuit.
Jul 08, 2016 | LG Audio Players & Recorders
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
Dec 20, 2012 | Sony DAV-HDX500 System
I have a Sony receiver STR-DG510. I was playing music through the receiver when it suddenly stopped and displayed/flashed protect. After unplugging everything and trying a different power outlet it still...
Most likley it is a bad channel. Needs output transistors and a couple of resistors. or it may need a pre-amp voltage ic.
Not a repair for your average do it yourselfer.
Jun 30, 2010 | Audio Players & Recorders
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
Dec 20, 2008 | Sony MUTEKI HTDDW1600 Theater System
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
359 people viewed this question
 Grubhead
Grubhead
