Question about RCA Televison & Video
RCA TruFlat TV
Mod 20F420T
Service Number 20F420T C211
Sreial Number G145E5634
TV turns itself off repetededly without reason.
Automatic off time is disengaged.
Occurrs at various times of day.
It is necessary to turn TV on over and over again, up to 5-6 times, before TV finally stays on.
No other remote control devices are in the room or area that may be sending signals to TV
Please advise as to problem or suggestions.
Thank you.
Be happy to explain how I fixed the problem.......please send $40.00 and I will forward the solution!!!!
Posted on Mar 04, 2008
Remove fpa parental lock
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Sep 13, 2014 | RCA Televison & Video
I have an RCA truflat tv. Model # 20F420T. A
I see no reason why not, you just have to connect those 2 and you will be fine.
Aug 27, 2014 | Televison & Video
RCA truflat tv locked and is on standby mode. I have a universal remote but the remote will not work if the tv is on standby I need to find out how to unlock the tv with out the remote so I could turn it...
Okay, do this.
On the top of the t.v. itself, hold down the Volume+ (up) and the Menu button down at the same time. This will turn off the "power lock." This is also how you turn on the "power lock." (Though I can't think of a reason anyone would ever want to do this.)
Also the problem ca be from factory defect in the if and video section of the tv only the manufacturer could remedy that.take it to a tech so that the video board and the IF board be replaced
Hope it helps...Thanks ....feel free to contact me back ....Ok ?..
Apr 23, 2011 | RCA TruFlat 27F520T 27" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
My RCA TruFlat Model No. 20F420T shuts off at will. All the timers are set to off, any ideas?
HI,,
ITS NOT PROBLEM WITH TV TIMER...
ITS PRBLEM WITH TV AC TRANSFORMER WHICH IS INSIDE,,
ONE OF THE POSITIVE COIL INSIDE TRANSFORMER ITS SHORTING,,
APPROACH TV TECHNICIAN...
Nov 11, 2009 | RCA 20F420T 20" TV
My RCA TV model 20F420T keeps turning itself on and off. What is causing this and how can I fix it?
just remove all the tact switches on the front of the tv and use the remote control all the time.
Oct 25, 2009 | RCA 20F420T 20" TV
20" TruFlat cuts on and off on it's on
Hi
This is power supply issue! a defective parts need to replace. like power oscillation. here in the philippines the cost is about 750.00 php.
Thanks!
Dec 29, 2008 | RCA 20F420T 20" TV
Television
maybe the power switch of your tv is loosen,if not you may coldsolder the components of board of your tv.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
Televison & Video Logo
135 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
