Question about Frigidaire GSTF1670A Front Load Washer
Front load frigidaire washing machine
The spin cycle is louder than usual. There is no griding or clinking just a large increase in volume. Also at the end of the cycle there has always been a small amount of water sitting just inside the door on top of the rubber seal. Now that water is dark brown. When I washed jeans a couple pair now have dark stains on them. It looks like an oil substance.
Any suggestions?
  • 156 Answers
It is the rear bearing has went bad which is molded in the rear half of the tub which has a long warenty on the part only you usely half to pay the labor additional parts needed to repair after tear down
Posted on Mar 03, 2008
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
During the spin cycle, machine makes a loud clinking sound and cannot spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire stopped working
The bearings are bad. My sears kenmore did the same thing. Do you have hard water, that would be one cause. Or maybe it's still under warrenty because it is not a cheap fix.
Dec 31, 2009 | Frigidaire FTF530FS Front Load Washer
Why is my front loader so load when it spins?
If it gets louder as the spin increases then its most likely to be the drum bearings causing the problem.
This can be a very costly repair so I would recommend several FREE quotes before you agree.
aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Belts slips off
Belt is too loose and probably needs to be replaced.
Jul 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Frigidaire GSTF1670A Front Load Washer Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
