Question about Denon AVR-3805 Receiver
Blown output on Denon AVR3805
I very stupidly managed to short one of the output channels(surround back right, I think) on my reciever. I replaced the slow blow 3.15A internal fuse and it now tries to power up but goes into protect. Since I don't have ay circuit diagrams I took it to a local repair shop but they said it was rather a complex problem and they couldn't fix it without the service manuals/circuit diagrams. Surley this is likely to be an output transistor? The trouble is I don't know which one without the circuit diagram, and even then I'm not sure how to test it proprly to make sure. The other option is to buy a service manual from service manual.net but I don't want to do this if it's going top be no use, and I don't really want to take it to a denon dealer as the cost will probably be astronomical, and I was thinking of upgrading to a new onkyo soon anyway.
  • 979 Answers
This unit does not use "output transistors". The driver section uses hybrid packs that are usually two to a set. Knowing which set to replace is only part of the problem when replaced as bias voltage Must be correct...accordianman
Posted on Apr 23, 2008
Denon AVR2106 One output channel shorted and blown. 2 power transistors shorted, emitter resistors and base resistors blown Have replaced all, including bias transistor I think bias is still wrong (no...
I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
Sep 07, 2011 | Denon Audio Players & Recorders
I have done some research about my denon arv-1601 reciever, narrowed it down to a ressistor problem, it turns on for 4 seconds and turns off and goes into standby mode. Any Suggestions?
Usually it is bad power supply problem or bad channel problem. Look for any burned parts, it helps you locate the problem. Burnt resistors in one channel- you need to replace output transistors (better to replace all transistors in that channel) and bunch other surrounding parts. If you do not see any burned parts, check all voltages coming from power supply +15 -15 +5 etc then check dc at every channel output (not at speaker terminals but at control pins on the amp/main pcb), should be +-10mV
Sep 05, 2011 | Denon AVR-1601 Receiver
Smoked a card or module on top left hand side of reciever and none of my speakers on surround sound and throughout the house work.Is it worth fixing or get a new receiver?
I think one of the amplifier channels is blown. The repair is about $120. Check prices for new receivers and decide. Thanks.
Aug 14, 2011 | Denon AVR-1700 Receiver
I just received a Denon AVR-4308ci receiver. I have two passive subs in my system. The receiver only has one powered output. Since I am not using the surround back speaker outputs can I use these for the...
Sure, if you want to hear Surround Back program material coming from the subs without midrange or tweeters. (Sarcastic) Of course, the LFE program material will still be going into a black hole somewhere.
Run the subs in series with each other -
Sub Amp negative to 1st speaker negative;
1st speaker positive to 2nd speaker negative;
2nd speaker positive to amp positive.
Run the speaker level adjustments routine and enjoy.
Just for giggles, try what you were thinking about. You won't hear much from the sub(s) unless you programmed the Surround Back channel as full-range and then have something like the Apollo 13 launch for program material. Normal audio won't send much low-frequency material to those channels. The optimal place for subs is on the LFE or sub channel.
Nov 17, 2009 | Denon AVR-1507 Receiver
No surround back channel - damage during transport
I think your receiver has cracked main (amplifier) board close to surround back channel terminals. Need to take apart the receiver remove the board, inspect it and resolder cracked traces. Unfortunately it is not so easy to remove that board and probably you need to bring it to a repair shop.
May 18, 2009 | Denon AVR-4308CI Receiver
NO LEFT, RIGHT, AND CENTER SURROUND
hi there
have u tried connecting the centre speaker to another amplifier to see if the speaker actually works....
if it does then it cud be the output transistors blown or the actual OP-Amp for that channel
Feb 23, 2009 | Harman Kardon AVR 130 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
I need to set up 4 pair of speakers, two zones. all ceiling mounted.
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
Nov 06, 2008 | Denon Audio Players & Recorders
I think my amp is broken
Finals/outputs are toast. Get it serviced to get back to sweet music...accordianman
Feb 21, 2008 | Denon AVR-2807 Receiver
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
Denon AVR-3805 Receiver Logo
218 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
