Question about Crown CE1000 2-Channel Amplifier
Sound how to bridge my power amp to get the max out of it/?
  • monmax Mar 04, 2008
    thank you Jango for your help .can you send me a hand made diagramme.[picture so i can understand better]
  • 38 Answers
Hi monmax,
I hope you are aware that in bridged mode your amp will become monaural (single channel, double power). If you still wish to bridge it:
Switch of power.
Set mode switch behind amp to "bridge" position.
Connect speaker positive to CH1+ve terminal of amp output and connect speaker negative to CH2 +ve terminal.
Be aware that now, in bridged mode your amps output power delivery is 1100 watts for a 4 ohm speaker and 900 watts for an 8 ohm speaker. Make sure your speaker can handle that.
Peace
Jango.
Posted on Mar 04, 2008
Which amplifier is best suitable for me to use?
This really depends on the setup you intend to create in your vehicle.
The Amplifer (amp) needs to be matched to the speakers you intend to run.
As a rule of thumb, the power of the amp shouldn't exceed the max. power of the speaker (this may damage your speaker). Instead, the amp's RMS output power should be at 75-100% of the speaker's RATED (RMS) input power. NOTE: this must NOT be confused with max power.
Ideally, you want to run each speaker with its own amp channel.
A subwoofer will usually require a hi-power single channel amp, or a 2 channel amp, bridged into 1 (to increase power output required for the sub).
Here are some examples in simpler terms:
1 channel (hi power) amp can run a subwoofer.
2 channel amp can run 2 speakers, or 1 sub (bridged).
4 channel amp can run 4 speakers, or a combination of 2 spkrs + 1 sub (bridged), or perhaps 2 subs (bridged).
Hope this makes sense.
Feb 27, 2013 | Car Audio & Video
How can you bridge a 2 channel 300 watt amp to a 4 channel 300 watt car amp?
if you have (4) 4 ohm speakers (No Subs), then you simply take the (2) positives from the two right speakers, and the (2) negatives together and put them on the right output of the amp. Do the same for the other side. This will have the amp at a 2 ohm stereo load on each side, which will max out the power of the amp. Will sound great with any small power amp.
Sep 07, 2011 | Car Audio & Video
It was laying on the workbench in my kids stole the fusesWhat size fuses go in a koiiler model 9696 1000watt Max amp? To bridge this 4ch to 2 on the high input side. do you have to tie the input side??...
NO dont tie the inputs. Inputs stay just as they are. Outputs are where the bridging happens.
You amp specs are:
XM-9696 C/W 4 CHANNEL POWER CHROME/WHITE AMPLIFIER
MAX OUTPUT POWER (2 OHM): 200W X 4 = 800W
POWER OUTPUT: 90W X 4 @2 OHM (360W) LESS THAN 0.5% THD
60W X 4 @4 OHM (240W) LESS THAN 0.3% THD
BRIDGED 180W X 2CH @4 OHM
So lets take 800 watts and divide by 13Volts DC = 61.54 Amps
So if there are 2 fuses start with 30 amp. To play it safe you could use 25 amps and if they blow try a 30. Now if the 30 blows you may need to take
another look at your wiring. I think 30 will be fine though.
Apr 02, 2011 | Car Audio & Video
I got a cadence q 4000 and i what a the bass to sound louder
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
Jul 31, 2010 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Sub not working
you need more power like gettin a bigger amp
May 03, 2009 | Kicker 05C104 Car Subwoofer
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Alpine mrp-350 amp
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Feb 18, 2007 | Alpine MRP-M350 Car Audio Amplifier
Crown CE1000 2-Channel Amplifier Logo
326 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
