Question about Ricoh Aficio AP410N Laser Printer
Error Code SC842
I came in this morning to this error code on the display. Below it are then numbers 1401 80000000.
We had a power failure over the weekend. i am guessing that is what caused this? I can't find any documentation on the error.
  • Dwalker Mar 04, 2008
    It is error code 824
Cogz
  • 1326 Answers
SOURCE: error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Posted on Feb 10, 2008
  • 64 Answers
SOURCE: Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
Posted on May 24, 2008
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
bschilz
  • 2049 Answers
SOURCE: error code
Owners manual states "Turn the power off, and then on. If the message appears again, contact your sales or service representative"
If you need a copy of the owner's manual, go to...
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/p610n/p610nen.htm
Posted on Aug 14, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
Posted on May 05, 2010
Testimonial: "fantastic advice and thanks for all the information. That was my exact problem. Thanks for the information. Much appreciated. "
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Dead
    Hi
    THe most common beeps that you will encounter 95% of the time in repairing PC's are:
    1 beep - computer ok
    continous beeps / long beeps - memory error
    continous short beeps - bios boot block/corrupted bios
    1 long beep followed by 3 short beeps - video card error
    or this might help
    you can check out this list
    AMI BIOS
    1 short - Computer ok
    2 short - RAM failure
    3 short - Parity RAM failure
    4 short - System timer failure
    5 short - Motherboard failure
    6 short - Keyboard controller error
    7 short - CPU failure
    8 short - Video RAM failure
    9 short - ROM BIOS error
    10 short - CMOS read/write error
    11 short - Cache RAM error
    1 short, 3 long - Memory failure
    1 short, 8 long - Video adapter failure
    Check board/chipset makers website for more infomation.
    AWARD BIOS
    1 long - Memory error
    1 long, 2 short - Video error
    1 long, 3 short - Video failure
    Continuous beeps - Memory or video failure
    note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
    Standard IBM beep codes.
    No beep - Power supply or motherboard failure
    1 short - System is ok
    2 short - POST error (code displayed on screen)
    Repeating short - Motherboard failure
    1 long, 1 short - Motherboard failure
    1 long, 2 short - Video display adapter failure
    1 long, 3 short - Video display adapter error
    3 long - Keyboard error
    Pheonix beep codes
    1-1-3 CMOS memory failure
    1-1-4 BIOS failure
    1-2-1 System timer error
    1-2-2 Motherboard error
    1-2-3 Motherboard error
    1-3-1 Motherboard error
    1-4-1 Motherboard error
    1-4-2 Memory error
    2-x-x Memory failure (any number of other beeps)
    3-1-x Chipset error (any number of other beeps)
    3-2-4 Keyboard controller error
    3-3-4 Video adapter failure
    4-2-4 Expansion card failure
    4-3-4 Time of day clock failure
    4-4-1 Serial port error
    4-4-2 Parallel port error
    4-4-3 Math co-processor error
    pls rate as fixya if it helps. thanks
    Jul 04, 2008 | Acer Aspire 5100 Notebook
    Tip
    Whirlpool duet F70 and F71 error codes.
    F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
    Repair is difficult, as motor, wiring and voltages from control modules must be tested.
    Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
    If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
    Here extensive explanation of error codes and relative troubleshooting:
    F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
    If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
    1. Check for continuity of the User Interface harness.
    2. Check wire harness connections to the User Interface and the Central Control Unit.
    3. Replace User Interface if drum is rotating.
    4. Replace Central Control Unit if drum is not moving
    F71: USER INTERFACE HEARTBEAT FAILURE
    If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
    4. Replace Central Control Unit if drum is not moving.
    To get parts and diagrams try entering the full model number in one of the websites below:
    Enter the model number ..
    To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
    on Nov 05, 2010 | Whirlpool WFW8300SW
    Tip
    Whirlpool Calypso Dryer Error Code Explanations And Repair
    Failure - Code Condition - Check/Repair
    PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
    E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
    • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
    Normal thermistor resistance values:
    • 60 degrees F. - 15.3K ohms.
    • 70 degrees F. - 11.9K ohms.
    • 80 degrees F. - 9.2K ohms.
    E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
    • This error code is displayed only in diagnostics mode.
    on Jul 19, 2010 | Washing Machines
    Error code OXC4B827F
    This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
    If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
    Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
    What is error 0xc19a0003 mean for the HP Officejet 4620
    ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
    May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
    I have a Kenmore model 11049962603 that displayed an f-71 error code. I ordered a new cpu computer from sears and installed it. the machine seemed to work for one or two loads. now it displays an f-70...
    I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
    The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
    Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
    Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
    If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
    This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
    Mar 27, 2011 | Kenmore Washing Machines
    PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
    AMI BIOS beep codes
    Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
    Beep Code Descriptions Document
    1 short DRAM refresh failure CH000996
    2 short Parity circuit failure CH000607
    3 short Base 64K RAM failure CH000996
    4 short System timer failure CH000607
    5 short Process failure CH000607
    6 short Keyboard controller Gate A20 error CH000383
    7 short Virtual mode exception error CH000607
    8 short Display memory Read/Write test failure CH000607
    9 short ROM BIOS checksum failure CH000607
    10 short CMOS shutdown Read/Write error CH000239
    11 short Cache Memory error CH000607
    1 long, 3 short Conventional/Extended memory failure CH000996
    1 long, 8 short Display/Retrace test failed CH000607
    For more information go to: http://www.computerhope.com/beep.htm#04
    Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
    My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
    F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
    2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
    Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
    What do codes e2 and f1 mean?
    Here is what the manufacture says about it, my comments are below.
    F1 E2 - UL A/D error(s)
    1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
    error code is displayed.
    2. Disconnect power longer than 30 seconds.
    3. Re-apply power and observe for longer than 1 minute.
    4. If failure remains, disconnect power, replace control.
    Phil's comments----->
    F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
    The part number for this unit is 4453614 and runs just over $300.00
    Apr 25, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
    Ricoh Aficio AP410N Laser Printer Logo
    129 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    OfficeServiceAjnc
    OfficeServiceAjnc
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
