Question about RCA P60920BL 60" Rear Projection Television
TV fried from power surge
My 60 inch projection tv was on, when a power surge hit, now the tv will no longer power.
Tried several different outlets.
If it is something that requires resoldering, I could probably do it if I knew what was supposed to be started where.
Any suggestions on what I should do?
  • 1 more comment
  • jparks34 Mar 03, 2008
    Ok, this is what I found when I went back there.
    The model number is actually P60828BL.
    The chassis is PTK195DC
    Thank you very much for your response.
    Correction, model number is P60820BL, instead of 8BL.
  • Anonymous Sep 09, 2008
    checked fuse by power cord connection on board, and it is good.
  • RCA Master
  • 8,617 Answers
What is the chassis number? It should be located on the rear of the set. Have to have the chassis number before I can help
Posted on Mar 03, 2008
I have a Sony 52 inch kdl-52v4100.had a power surge.now tv will not power up
Tv might be fried.Or one of the circuit breakers Is popped. Maybe try a different electrical outlet.
Apr 20, 2015 | Sony BRAVIA KDL-52V4100 52" LCD TV
The kids left the tv on all night and turned off in the morning. Next time we tried to use it, we had no picture (blank screen) and no sound, but the power light does come on. Where can I start looking for...
I don't know of a parts outlet but searching will find this part. I am betting that you blew out the video card itself. This usually happens with a lightning strike or a power surge and a power surge strip you buy from a home center is not what it advertises and will not work. It will be obvious if you pull the back off of the TV and look at the input cards, one of them should be fried. If you find the fried one you can pull it, take off the part number and start looking for a replacement. These cards can be fixed but it will take someone that knows what they are doing and a ton of patients.
Jun 16, 2011 | Mitsubishi VS-70707 70" Rear Projection...
TV Wont turn on after lighting storm. I have tried to; unplug and plug back in. Unplug it for 24 hrs. Try different outlets. Look at the build, looks fine.
The TV circuitry is designed to protect from power surges. The fuse on the power supply may be blown, or the power supply itself could have taken a hit. I would try to check the fuse first and then if it turns back on... it did it's job!
Good luck! and let me know what happens!
Oct 12, 2010 | Panasonic PT-52LCX66 Projection Television
No power coming through even red light won't come on tried different cords. That didn't work either. And we had the tv on a surge strip along with the computer and it is fine.
Try plugging the tv in a different outlet in the strip. Maybe the outlet it was plugged in during the surge got fried. I would bet thought the fuse on the power supply has blown and needs replaced. You will have to take the back cover off of the tv to find the power supply. Good Luck!!!! Hope this helps.
Mar 08, 2010 | Protron PLTV-32 Television
I had a power surge last night do to a storm and now my Projection TV won't turn on. Is there a surge protector inside the TV that I can reset or is the TV fried?
there are several fusses in a hitachi located in the power board if your lucky one of them took the hit you can , or have atech look for you the gma type fuse are avail at Radio Shack or your local tv shop
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
141 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
