Question about Minolta DiALTA Di181 Printer
Error code 1300
Machine comes ready , when hit the print button the jam light goes on . clear the jam , c-1300 appears.
  • 25 Answers
THIS ERROR IS CAUSED BY POLIGON MOTOR OF THE LASER SISTEM. IF YOU CAN GET TO IT, JUST OPEN IT , LUBRICATE DE SHAFT AND YOUR PROBLEM WILL BE SOLVED. GOOD LUCK.
Posted on Oct 30, 2008
  • Tizora John Feb 22, 2011
    Keep it up Master,from Jotzpro@gmail.com
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
Mar 19, 2013 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Paper jam error code with no paper jamb
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq17
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
370 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
